Reduced Power to only 4 cyl???
Old 10-06-2013, 09:40 PM
C5-1
C5-1's Avatar
Default Reduced Power to only 4 cyl???
I got Reduced engine power message and service traction control this morning. The car turns on normally and idles normal. After the message I went around the block and the car felt it was running on 4 cyl. I then decided to go to the auto parts store to have someone scan the car and it came up with;
P0122 TPS pedal position sensor A circuit low input
P2135 TPS pedal position sensor switch A/B voltage correlation
On my way to the auto parts only the check engine light was on and the car was running perfectly. Before I got there the light was off.
Any ideas on what's going on???
PS
I'm not sure if this matters (I think it has nothing to do with it) but the message came up when I was washing the car. I started washing with the cars nose facing my house, but because the hose wasn't long enough I turned the car around and when I was backing up to the driveway I got the message.
Old 10-06-2013, 10:18 PM
not08crmanymore
not08crmanymore's Avatar
Not 4cyl. it just does the reduced power thing when it needs to.Maybe a bad battery or something got wet. This ain't no C7,so no cylinder deactivation...you're always on 8 cylinders.
Old 10-06-2013, 10:23 PM
C5-1
C5-1's Avatar
Yes I know...I simply meant that the car feels it's running on 4
Old 10-06-2013, 10:33 PM
not08crmanymore
oh.lol
Old 10-06-2013, 11:38 PM
Justingoesham
Navigator
Justingoesham's Avatar
when it happend to me it was because water got sucked up into the maf and got it rather wet. all i had to do was dry out the maf and take the battery off for about 15min and it was fine.
pretty much just pull your intake and maf off dry it out and let it sit with the battery off for 10-15min and you will be fine.
on a side note i had to do it twice for it to go away guess i didnt dry everything out good enough the first time.
Old 10-07-2013, 10:24 AM
truckplay
truckplay's Avatar
you will need a new gas pedal assembly $100 at the dealer. takes 15 miutes to swap out.
they use to fail from time to time.
Old 10-11-2013, 04:28 PM
Chevy Cust Svc
Chevy Cust Svc's Avatar
Hey C5,
If you do decide to take it into the dealer, let me know! That is where I can help out. If you find a DIY, keep us posted on that too.
Kelly J.
Chevrolet Customer Care
Old 12-10-2013, 09:09 AM
chedrool
4th Gear
chedrool's Avatar
Default Check engine, service traction and service active handling
Originally Posted by Chevy Cust Svc
Hey C5,
Kelly J.
I recently encountered the same problem on my 2012 C6 base that only has 200 miles on it. It will be at New Rochelle Chevrolet tomorrow and any support you can provide would be greatly appreciated.
Frank S.
Old 12-10-2013, 10:31 AM
smurfkiller
smurfkiller's Avatar
unplug the throttle body make sure the connector is clean and dry plug it back in. happened to my buddy once just unplug and reconnect never did it again.
Old 12-10-2013, 12:00 PM
cclive
cclive's Avatar
This would be my first thought also. Try unplugging and spray contacts with cleaner...
Old 12-10-2013, 02:28 PM
Cherokee Nation
Cherokee Nation's Avatar
Were you washing your engine????
Old 12-10-2013, 02:42 PM
Cherokee Nation
PS
My 08 does the same every time i get in loose gravel,it shut down for about 2 seconds then back to full power..Normal
Old 12-11-2013, 07:49 PM
Chevy Cust Svc
Frank S.
Hi Frank,
If you haven't already, shoot us a PM with your contact info and VIN. We'll gladly take a look at your situation!
Marissa
To Reduced Power to only 4 cyl???
Quick Reply: Reduced Power to only 4 cyl???
