Dewitts radiator replacement
3rd Gear
My radiator started leaking in my 2005 C6 standard transmission but it has the oil and transmission Coolers in the radiator I got a Dewitts replacement radiator and had the dealership installed it the problem is that they say the sway bar it is hitting the fan shroud when the car is on the left but it does have clearance when its on the ground is this a problem I can get no response from Dewitts
Last edited by richard98052; 10-08-2013 at 02:37 PM. Reason: Tony Miller said I'm not posted in the correct forum
I installed a Dewitts on my 2009 and did not have this problem. I am wondering if the Stealership properly installed the fan shroud? I have Z51 sway bars which are fatter than the base on and they are no where near it. Unless your car is not at the proper ride height?
