Left key FOB next to car - new FOB battery dead in 10 days
So, I was getting sick of trying to open the door to my 2008 Coupe and forgetting to bring a FOB out into the garage with me, so I took one of the FOB's and left it on a shelf, within 6 feet of the car. The FOB had a brand new CR2032 battery in it.
Today (10 days later) I went out to open driver door, and nope, door would not open. I picked up the FOB and tried to lock/unlock and got no response. I took out battery and it read 2.42v (effectively dead).
If you leave a FOB close to the car, does this normally cause a drain to the FOB battery, or is something else going on??????
Thanks, Dave F.
Thanks, Dave F.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,819 Likes
2015 C7 of the Year Finalist
No FOB battery drain occurs without direct action from you.
When you touch the door pad the FOB battery is used to communicate with the car to let you in.
When you press the Start button the FOB battery is used to communicate with the car to allow it to start.
When you press the button back by the rear license plate the FOB battery is used to communicate with the car to give you access to the rear hatch/trunk.
When you turn off the engine the car looks for the FOB and the FOB battery is used to communicate the FOB's presence.
Other than that, you must push a button on the FOB to use the FOB battery.
So, if it's just sitting there, say on the hood, no battery drain at all on the FOB UNLESS a button is stuck "on" and then your juice is flowing.
Elmer
Elmer
Elmer
Thanks guys! I appreciate the answers...................
I had a similar problem with a Toyota Camry. The problem as explained by the dealer is that these new cars are electronicly talking and listening all the time. They send out a quire to the fob, it does answer and in short order the battery is dead. I was warned to keep the fob away from the car like even inside the house it can be drained. Look in your manual, if you don't drive your car once a week the car battery can drain down, that is because all the electronics are talking even though you thnk they are shut off.
Well, I am gonna conduct an experiment. I will put new battery in FOB and replace it in same spot. I will measure battery voltage before and after, just to confirm I put a good battery in to begin with.
Thanks very much!!!!!!!!
And to Chevy SS, why not just turn off the auto lock feature? I leave it off for the same reason. I dont want to need to bring a fob with me to the garage every time I want to just open the door.
Elmer
Elmer
So the 'proximity aspect' of the car/fob only works when you are walking away from the car? In other words if you are getting out of your car and walk away with the fob in your pocket, the car 'senses' the same and locks and alarms the car. But if you are approaching the car with the fob in your pocket the car has no 'automatic communication with the fob triggered by the close proximity, to perform any unlocking or other functions?
Elmer
^ So, in the OP's case, what happens if you are walking away from the car with the fob in your pocket or hand, but never get a sufficient distance from the car for it to lock and alarm . . do the car & fob keep communicating 'awaiting' that action?
When you push the button to turn off the engine, the car looks for the FOB. If it finds the FOB, it turns off the engine. If it does NOT find the FOB, it pops up a message saying it can't find the FOB and are you really serious about turning off the motor. You push the button again and the car turns off.
So, you have the FOB in your pocket and you push the button, the engine turns off. You open the door get out, the car sees the FOB leave the car and then it starts to lock and set the alarm and crap. IF you open the door and set the FOB on the console and then get out, if the car is set up to alert you of a FOB in the car, it will honk 3 times to let you know the FOB is in the car and you're getting ready to learn a locksmith's phone number (unless you can get the 2nd FOB! ). The car doesn't track you down the street or keep track where the FOB is after you get out and close the door.
Elmer
Elmer
LOL, yeah, I guess it would help to read the owner's manual. Honestly, I truly hate the whole keyless-start FOB thing, so I haven't bothered to study up on it. I'd much rather have a traditional key to start/run the vehicle, and use the FOB to open doors/hatch/etc. I completely fail to see how the FOB makes anything easier.
Put the fob in your pocket and leave it there the whole time you're using the car. Now go somewhere, park the car, kill the engine and get out of the car. Shut the door. Pretty easy process, wasn't it? Didn't have to take a key out of your pocket to get in it. Didn't have to put a key in the ignition, didn't have to remember to take the key out of the ignition, didn't have to remember to lock the car, didn't have to put the keys in your pocket.
Come back out of the store carrying what you bought. Don't have to switch hands to fish your pocket for your keys to get in the car. When you get home, don't have to use keys to lock the car. Don't have to juggle the keys if your hands are full of what you bought.
Yeah, fobs are really a pain.
Do you have a cell phone, or do you wait until you get home so you can use your old rotary dial telephone?
Received 2,049 Likes
St. Jude Donor '13
Just attended a new owner seminar on behalf of one of my kids and the dealer said exactly this^. They warned not to leave fob in vicinity of car. Evidently their system works differently then GM's and their fob has a little red light on same that shows when car is trying to communicate without any action on driver's part. Different strokes for different folks!
I'd give it 50-50 that the Toyotas are actually different, or the dealers are, uh, misinformed.
Standing by for further information...
