Ken @ KNS will go above and beyond to meet your needs. He is outstanding. Saved my butt when I needed DBA rotors and NOBODY had them in stock. Saved me a ton of $ too!
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Great site, glad you posted. For a base 08 C6 will the centric premium rotors with hawk pads be a good replacement for stock base pads and rotors. What I would like is resistance to rust and less brake dust. Thanks again
The Centric Premium's do have a very nice coating that is long lasting under most normal conditions. Track like temperatures will cook the paint off in the vanes but that takes some work.
There is also a bit of what we call a rust ring where the surface coating is ground away just a bit more than the pad width but that's not too noticeable.
For low dust I'd go with Hawk Ceramic pads. You will always lose some bite w/ low dust pads but the Hawks are not bad. HPS are mid dust -probably more like the OEM pad but retaining more bite.
