Voice Commands Are Misunderstood
I have a 2013 GS vert with voice command nav and bluetooth. The owner's manual provides a list of commands but my system misinterprets them every time. I'll say "Display Off" and the system will respond with something like "Historical POI's Displayed" which isn't even close to what I said. It is my understanding that the C6 nav/bluetooth system in a 2013 is essentially unchanged from 2005. Has anyone else had a "failure to communicate" like me?
Haven't really used it in the Vette, but when I first purchased my Yukon I found voice recognition would err if you talked too loud. If I remember correctly there is something in the instruction manual for the system about talking in "normal voice level" or something to that effect.
People complain here all the time how horrible the nav is when the problem is actually that they just haven't taken the time to understand how to set all the hundreds of options. In this case, however, you are right. Talking to the nav can be like talking to "tech support" but there is hope.
OK, here is what I have found. The software behind voice recognition is trying to match sound frequency and timing to an internal database. So what is needed is to recognize what the designers would have thought you would sound like. They would have not expected you to be yelling. If you talk too loud the microphone can't handle the volume and clips the tops which has the same effect as increasing the high frequencies. They would have not expected you to whisper. The would have selected a neutral accent. If you're from Bahstn, fugetabotit bru. Finally, they have a limited amount of memory so there is a limited vocabulary. It is "Screen Off", not "Display Off". The one that always trips me up is everything is guidance this and guidance that but it is "Cancel Destination", not "Cancel Guidance". So the tip here is to talk normally using the correct words in a dialect you would use in a job interview. It's two words - "SCREEN OFF", not "SCRaNAUF".
Next the processor is analyzing frequencies and timing. You are more likely to get the correct result if you emphasize the frequencies it is looking for. Yes, is pronounced YYessssss. Screen is sskrreeeenn. Always extend and hiss the s's, keep a constant low frequency for many letters and use crisp k's.
The system is designed for short commands or long commands. You can say "Right Map Change to North Up Mode" or "Right Map Show North Up Mode" or "Right Map North Up Mode" or "Right Map Change to North Up" or "Right Map Show North Up" or just "Right Map North Up". My experience is the fewer words you use the fewer chances it has to make a mistake. It also means you have fewer chances to use the wrong word. Say "Right Map Display North Up" and it will never work.
With these tips you should be able to get 95% correct while sitting at a red light and 90% cruising on a smooth Interstate. But increase the background noise by accelerating with noisy tires on an oiled street with the windows down and it will be lucky to get it right 5% of the time. My experience is that I almost always try the voice command first and it works well enough I seldom have to resort to pushing buttons.
Grrr8888 post.
How do you get it to answer. I have a Samsung Galxy. When it rings I must take it out of my pocket and swipe it to get it to answer. I push the answer button on the steering wheel but no joy. I push the phone button that pops up on the dispaly and also no joy. Once it is on I can put it down and talk.
Any hints?
Any hints?
You can try what I do: Scream your command interspersed with a stream of expletives. It doesn't work, but it makes me feel better!
Grrr8888 post.
Any hints?
Any hints?
Grrr8888 post.
Any hints?
Any hints?
Grrr8888 post.
Any hints?
Any hints?
To answer I hit left side screen button usually.
Giving commands I use a low voice, like mentioned above I just make sure to distinguish my words.
(08 c6 nav unit with ISIMPLE 21 Bluetooth in my '05 c6)
I had the same problem and called the tech group and they said if you have the nav system you need to hold the answer button for 2 seconds . I did that and it works perfectly I took a second look in the the manual and that is also what it says
Grrr8888 post.
Any hints?
Any hints?
Grrr8888 post.
Any hints?
Any hints?
Well I went to the car and used some of your suggestions as well as going over the nav guide and guess what I got very good results.
I plan on spending more time with the system and getting better results.
Nice Job
BLUE MAX
Nice Job
BLUE MAX
Received 2,051 Likes
St. Jude Donor '13
St. Jude Donor '13
But it still only gets me what I want, about 50% of the time.
My 2006 phone system never got anything right, I just don't use it. Must be me cause the Nissan Leaf Bluetooth doesn't recognize what I say either. Works perfectly for the sales person?? Very frustrating!!!!!.
all voice commands suck. it's not just our nav. system, it's anything and everything to do with voice commands. did i say that right?
