car hauler recommendations needed
I'm moving from the SF bay area to Houston next spring (Feb-Mar). I'm looking for recommendations for a car hauler to move my '13 vert and '14 Silverado. Perferably enclosed trailer with lift gate loading (front too low to get up a ramp without having to remove too many parts).
TIA,
Ken
TIA,
Ken
Intercity Lines
Intercity Lines, a forum sponsor.
No ramps, used a platform lift. The car, while inside was covered with a soft car cover. Driver was a Corvette owner and kept contact with me during delivery. Dropped car off at my front door.
Did a great job for me from Indy to Sacramento, CA.
even at stock height you needed a crap load of boards to get the car up the ramps without rubbing the bottom bumper.... then you need boards along the entire trailer where the tires roll over so the car can clear the front of the trailer and even when you get the car on the trailer and clear the bumper and keeping the car from bottoming out, the straps holding the tires down will rip off the air dams in front of the tires if not removed and will apply retarded amount of upward pressure to the bumper causing it to bend once strapped down.
I don't think my '13 427 CE vert is going to make it up a ramp for a UHaul trailer. I would need to the remove the chin splitter and side body aero parts. My ride is at stock height. I think the best way to go is with someone with a lift gate trailer.
