Door won't open
I am glad that they had you in an out in about an hour. That is excellent Customer Service!
I hope you had a great Thanksgiving,
Kelly J.
Chevrolet Customer Care
It looked like something behind the plastic trim behind the drivers side seat on the side of the car. It was approximatle at ear height. He never took the door panel off and didn,t appear to work on the door itself. He is their corvette specialist and only works on vettes. I will look at the paperwork and see what part was replaced.
Borh outside and inside buttons didn't work. You could hear the actuator, but the door wouldn't open. It acted like it opened an a half inch and i had to use the lever on the floor to open it all the way.
Moderator
Received 3,582 Likes
ok thanks,i work parttime for a local used car dealer and we have a 08 that will not open from the inside,trying to figure out what the deal is,lol
btw,hrs your vette looks a lot like mine,good taste!
I replaced the door latch actuator on my 05 and the door latch worked for a while then quit. Turned out I had a bad Body Control Module (BCM) that didn't send enough power to the door latch. replaced the BCM and all is well. It's pricey though. You have to replace the part then have a dealer reflash the BCM to your car. Could be that or maybe just the inside button?
After fixing the door, drove straight to a tint place and got 15% put on the doors
no,they door button on the inside does nothing but make the red light on the door panel come on.this car has aftermarket lambo style doors so there is no telling what is causing the problem.
