Brake Pads
Old 12-30-2013, 05:10 PM
ltreggerjr
ltreggerjr's Avatar
Default Brake Pads
Time for new brake pads. Should I go ceramic or OEM. Not looking to track or race but do like speed. Who's got the best pricing?
Old 12-30-2013, 05:31 PM
Cherokee Nation
Cherokee Nation's Avatar
Gm parts house....
Old 12-30-2013, 09:49 PM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
I just changed out my original pads for OEM ceramics. I'm hoping that there will be less dust.
Old 12-30-2013, 11:11 PM
Cherokee Nation
I put them on my & they cut the brake dust down about 85%......
Dee breezy (02-25-2024)
Old 12-30-2013, 11:24 PM
Jim Tom
Jim Tom's Avatar
Hawk Ceramic from GM Parts House. Less brake dust but I would guess closer to 50%.
Jim
Old 12-30-2013, 11:34 PM
Batmbl
Batmbl's Avatar
Have had mine on for 5 years. Love them (oem ceramics).
Old 12-31-2013, 10:32 AM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Check out the Carbotech 1521 pad. This pad will perform on the street while maintaining low dust and rotor friendliness and last 2-3 times longer than OEM. I will be happy to help you if your interested, you can call me direct at 216-780-8825.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
F $140 R $121
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 12-31-2013, 12:47 PM
Mike's LS3
Mike's LS3's Avatar
2008 Z51 - I replaced all four brakes with oem pads and rotors. No issues before and no issues after, so I staying with what I know works. I can deal with a little brake dust.
Old 12-31-2013, 01:06 PM
traderfjp
traderfjp's Avatar
I've been doing a lot of research on pads. A lot of guys are happy with Akebono and Wagner. They are much less expensive and have garnered great reviews. Do a search. Hawks have gotten mixed reviews and it doesn't make sense to go with oem when you have a chance to use ceramic brakes and cut down on dust. They put them on the ZR1 so they must be good.
Old 12-31-2013, 08:38 PM
ZR1-ab
ZR1-ab's Avatar
I have a 2010 GS and hear folks talk about padlett and single pads, what is the difference and how do I know which ones I need?
Old 12-31-2013, 08:41 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,099 Likes on 810 Posts
Jim
What I run and they have performed nicely for 40k now
Old 12-31-2013, 08:46 PM
berk4422
berk4422's Avatar
07 Vert using GM P/N fronts-88909667 Rears- 88909668 Love em
Old 01-01-2014, 02:00 AM
Knob Jockey
Knob Jockey's Avatar
St. Jude Donor '11-'12-'13-'14-'15
I have had Hawk ceramics on my Z06 brakes for 21K miles. No issues and much less dust than OEM.
I will seriously consider the Carbotech pads for the next replacement/upgrade.
Old 01-01-2014, 12:03 PM
C6ToGo
C6ToGo's Avatar
Received 1,116 Likes on 693 Posts
Very satisfied with Wagner Thermoquiet semi-metallic. Great bite, less dust, no squeak. 40 bucks on Amazon.
Old 01-01-2014, 12:33 PM
ls1121
ls1121's Avatar
St. Jude Donor '14-'15
Advance Ceramic Gold. I put the on all my vehicles.
Old 01-02-2014, 10:01 AM
Supporting Vendor
What year and model is your car?
Old 01-02-2014, 10:29 AM
Copterdoc
Copterdoc's Avatar
I had OEM pads on my 2009 C6 Coupe when purchased in Jan 2013, it had the dreaded squeal when brakes were slightly applied, which I tried to live with. In August, I put OEM Ceramics on all four corners. The squealing stopped for approximately 1 month, but came back with a vengence. It was virtually constant, no matter how I applied the brakes. In November I put on Akebono Ceramics, and not a sound, I couldn't be more happy with them.
Old 01-21-2014, 11:10 AM
Boxcar
Life Starts at 120 mph
Boxcar's Avatar
NCM Lifetime Member
I too have a 2010 GS, simple padlett equals 4 small pads per caliper. (2 each side of the rotor)
single = a one piece pad; one pad each side of the rotor.
Old 01-21-2014, 12:04 PM
96GS#007
96GS#007's Avatar
Received 1,732 Likes on 1,046 Posts
Mods,
Is there a way to make a "brake pad" sticky? This topic must come up 2-3 times per week and it has the same answers...
Some like Hawk flavors
Some like Carbotech flavors
Some like GM ceramics
Some like Akebono (only available for base models)
The occasional AutoZone or other brand pad gets tossed into the mix
Many confuse and confound by interjecting GS & Z06 pad discussions with discussions about base car pads (or vice versa)
Some get brake squeal, some don't
Some fix the squeal by occasionally braking hard, for some that doesn't work
Some use 1 piece pads for the GS & Z06
Some stick with padlets for the GS & Z06
Google has all sorts of pics of all of the above
To Brake Pads
Quick Reply: Brake Pads
