Headlight adjustment is loose
For some reason my headlight adjustment has raised causing it to point high and blind on coming traffic. I tried adjusting it with the Allen wrench and at first it fixed it. Then I banged on the headlight some to make sure it was good. As I started banging it the light starting moving up back to the high and out of alignment position. So again I adjusted it. Same thing. Now it won't even adjust at all. It just spins and the headlight won't move up or down. It was recently in the body shop and I had to take it back to them yesterday due to the headlight not being properly aligned. Do you think my headlight is damaged? I did have a hit and run in a parking garage, but there was no damage to the headlight housing. Only the bumper underneath the housing. Can this be fixed?
