C7 Steering Wheel on C6
Kinda weird question but I wonder if the C7 Steering wheel would be a direct fit for the C6. I know the C7's diameter is smaller but figured i'd raise the question.
Savvy75 (11-23-2021)
I can't help you, but the museum has a picture of the new Z06 steering wheel with a flat bottom. If it appeals to you, you might want to wait to see if it fits.
http://www.corvettemuseum.org/specs/2015/index.shtml
Don't know if it will bolt on, but the airbag and other controls will probably be an issue. Let us know what you find out
Pfadt Race Engineering
888-972-2464
info@pfadtracing.com
888-972-2464
Received 2,047 Likes
St. Jude Donor '13
Just personal opinion, but that C7 steering wheel is the ugliest I've ever seen.
The smaller diameter might be nice, but I'd need to drive with my eyes closed so I couldn't see the steering wheel.
Besides that would be a poser-ish move...be proud of the C6 you have...don't put C7 parts on it...might as well throw a stingray badge on while you're at it...not trying to be a d##khead but I just don't want to see a fellow vette owner make a bad move...peace and love to all...
The following 3 users liked this post by DPRVette:
The only problem with aftermarket like Caravaggio is the diameter- it doesn't change. I wish someone made a smaller diameter wheel that would take the OE steering controls/airbag.
Well so far you got no answers but a lot of opinions. I like the wheel and was thinking the same thing a couple of weeks ago. Keep the thread up maybe someone will give you the answer. I put a 2012 GS wheel on my car.
X0ctogonapus (05-06-2019)
hello there, another 2 bits in the mix....if your going to change anything visual on a corvette such as a steering wheel don't go aftermarket, keep it in the corvette familyhttps://www.corvetteforum.com/forums...es/cheers2.gif
Received 2,060 Likes
I always love threads like this where someone wants to make their car different by using parts from a different year or generation Vette. Usually stuff from the same generation will swap, but rarely otherwise. I respect the ones who have the guts to try it and especially those who tried and failed, but let others know the problems encountered.
I wish someone had tried to swap out a 6L80 for a 6L90, rather than simply saying it's too long. Now that the C7 started out with the A6 and switched to the A8, it seems fairly likely that someone will try that swap into a C6 car. Century and RPM, are you listening?
Prowler358 (01-12-2020)
