3 Ways to control your NPP Exhaust with Sunset Orange Creations Exhaust Commander!
Old 01-14-2014, 06:42 PM
SunsetOrangeCreations
SunsetOrangeCreations's Avatar
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
Default 3 Ways to control your NPP Exhaust with Sunset Orange Creations Exhaust Commander!
3 Ways to control your NPP Exhaust with Sunset Orange Creations Exhaust Commander controllers!
With remotes - Exhaust Commander 1 Button, See the all new keyfob remote below!
With the universal visor remote - Exhaust Commander Car2U visor compatible.
With the Exhaust Commander Elite, Turn your cars door panel lock button into your exhaust controller!
I have introduced many new innovations in bi-mode exhaust controls over the years. User selectable rpm opening, ZERO Battery Drain remembers last setting mode, Doorlock Corvette keyfob control, and Navigation address entry unlock with the C6 Navigation Commander.
Now we have the Lear car2u visor compatible Exhaust Commander that works with your universal visor on your 2006-2013 C6 cars! No Fobs needed!
As well as the amazing Exhaust Commander Elite with user adjustable rpm opening control.
Below are the descriptions of the different Commander controller models, click on the name to go to my online store to purchase one:
See the video! Use your Corvette's lock button to control your NPP bi-mode exhaust!
Both the interior door lock button and your cars keyfob remote can control your exhaust!
This is the new Exhaust Commander Elite NPP Z06 ZR1 exhaust controller, the most revolutionary exhaust controller ever produced!
The Exhaust Commander Elite install is very easy, is plug and play, and requires NO TOOLS or wire splicing of any kind! Installation instructions and user manual are available for download at www.sunsetorangecreations.com on the instructions page.
Please watch the demo video below, it was filmed in High Definition for your viewing pleasure.
With the car on, double-pressing the lock buttons on either door or your Corvette key fob immediately opens (LOUD!) and closes (QUIET) the exhaust.
The mode selected displays in your Driver Information Center (DIC), and HUD (if equipped) for three seconds, letting you know exactly what mode your exhaust is in!
Exhaust Commander Elite can also optionally open and close your NPP system at RPM values of your choice below 3500 RPM (USER RPM mode). The larger the difference between the open and close RPM thresholds, the less sensitive the opening and closing is with engine speed variations.
You can easily enable or disable the USER RPM mode. You choose whether you want QUIET and LOUD! modes only, or QUIET, LOUD!, and USER RPM modes. It's your choice, and you can change it anytime.
The Exhaust Commander Elite remembers its last setting and there are no battery drain concerns in any mode.
If you turn off your car in LOUD, it will start in LOUD.
If you turn it off in QUIET, it will start in QUIET.
If you turn it off in USER RPM, it will start in USER RPM.
We have an OBD-II splitter cable available that allows you to use the Exhaust Commander Elite and any other unit that needs to use the OBD port. There is a drop down menu that lets you add the splitter cable to your order.
Click here to place an order ---> Exhaust Commander Elite
The Exhaust Commander Elite price is on sale for $179.95 plus shipping.
We are offering some great limited time discounts to our CorvetteForum members. So use them while you
For those with old wireless controllers who want to upgrade we have a great deal for you!
Use coupon code: "tradein" and get free shipping. Then send us your working wireless controller and remotes and we will refund you back up to $50!!!!! Let us know what you want to trade in!
Only one coupon code can be used at time of purchase.
Get your Exhaust Commander Elite today!
Exhaust Commander Elite is designed and built in the USA, completely solid state, with no limited-life mechanical relay,
no extra remote controls to worry about and is designed not to prematurely drain your battery.
Exhaust Commander Elite is designed to outlast your car, using automotive grade electronics:
Its rugged specifications are intended to exceed expected usage.
Click here to purchase --->Lear Car2U visor compatible Exhaust Commander
Introducing the new Lear Car2U visor compatible Exhaust Commander Wireless NPP/Z06/ZR1 exhaust controller! For sale in our online store and ready to Command your NPP, Z06 or ZR1 Bi-mode Exhaust from one button on your 2006-2013 Lear Car2U visor! No Fobs Needed!
The install instructions are available as a PDF file to download at http://www.sunsetorangecreations.com/Instructions.php so you can view the instructions on any computer.
No Fobs are needed to open and close your exhaust from inside the car, just one button on your Car2U universal visor.
You can also have a keyfob remote added as an option if you would like to be able to open and close the exhaust from outside the car, but it is not needed for install or normal operation from the visor.
Take Command of you NPP, Z06 and ZR1 exhaust, you get to choose whether the exhaust is Quiet and mellow, and you also get to Command it to be Loud and mean when you want it.
Open and close your exhaust with ONE button on your Lear Car2U visor or with an optional One button Keyfob remote. Switch between Quiet and Loud anytime at the push of a button!
You press the button on the Car2U visor or keyfob remote once, the valves in the bi-mode mufflers close and you have the quiet factory operation mode, nice and quiet and opening at the factory rpm, press the button again, the valves open and you are in Loud mode and ready to rumble! Exhaust Commander is 100% Zero Battery Drain when the car is turned off.
Click here to purchase --->C6 Navigation Commander
C6 Navigation Commander allows address entry, searching points of interest, Nav setup changes, and access to stored destinations, all while on the move and it does not timeout and lock you out! If your going to install a PAL iPod interface you should get this controller and install it at the same time since you have to take the console off and access the NAV unit. Here is the thread with a detailed description.
See the Video below to show how it refreshes and doesnt lock out.
Exhaust Commander One Button
Click here to purchase --->Exhaust Commander One Button NPP / Z06 Wireless Exhaust Switch
The Exhaust Commander One button controller now comes with the new one button remote, see the picture below!
This is the Exhaust Commander One Button Wireless NPP On / Off switch. Only ONE button is needed for switching between Loud and Quiet modes. You press the button on the Fob once, the valves open, you press it again, the valves close again.
There is ZERO DRAIN on the battery when the car is off. The butterfly valves can start in any position, open or closed and you choose when you install it and can change it at any time.
This kit gives you the ability to open or close the NPP / ZR1 or Z06 butterfly valves using a One button wireless remote.
The install only takes 3 minutes to complete and can be removed just as easy without a trace. The only tool needed a 7mm nutdriver or socket. The option to purchase a 7mm nutdriver is also available if you dont have one already to do your install.
Kit includes a wireless receiver switch and Keychain One button wireless remote. This unit is not compatible with the 2006-2010 Lear car2u universal visor remote.
Add NPP exhaust to ANY C6!
This NPP retrofit kit includes the wireless controller with the Exhaust Commander one button keyfob remote, and all of the necessary vacuum lines, vacuum solenoid and wiring to complete the control system installation on a C6 that is retrofitting bi-mode exhaust.
It will give you full open / full closed modes and gives you the ability to switch between the modes instantly using the supplied One button wireless remote.
You can have the car start and the butterflies remain open until you close them, or you can have the car start and then the butterflies close until you open them. And can switch between open and closed modes with the One button wireless remote.
This kit uses engine vacuum as the source of vacuum to control the butterflies in the mufflers. The GM recommended vacuum port on the intake manifold is used just like NPP cars, Z06's and ZR1's!
The All-in-1 retrofit kit is now available with the Exhaust Commander Elite controller function.
If you would like to add NPP exhaust to your C6 and have it operate better than a factory car you want the Exhaust commander Elite All-in-1 NPP retrofit kit!
These products work on any C6 2005-2013.
Click here to purchase-->
Exhaust Commander All-in-1 NPP Bi-mode exhaust retrofit kits
Take a look at all the controller models we offer and get the one that best suits your needs.
If you need any additional info, let us know.
NPP Bi-mode exhaust vacuum retrofit kits -> Exhaust Commander All-in-1 bi-mode retrofit kit.
Our Online Store -> See all my Bi-mode Exhaust Controller Products! [/SIZE]
Old 01-27-2014, 03:26 PM
St. Jude Donor '13
Old 01-30-2014, 02:51 PM
St. Jude Donor '13
To 3 Ways to control your NPP Exhaust with Sunset Orange Creations Exhaust Commander!
Quick Reply: 3 Ways to control your NPP Exhaust with Sunset Orange Creations Exhaust Commander!
