Additional Mods during header install???
On my 2005 I had the tunnel plate installed from Elite Engineering when I did the headers.
Oh, and while you have it in the air you can also lower on the stock bolts.
Tunnel plate, and maybe different spark plug wires. Also have the bung installed (even if not used initially) to install an O2 sensor for a guage later. A SST plug will block it until you need it.
I hadn't thought about different spark plug wires, any suggestions? I think the PFADT headers already have an additional bung but I could be wrong. I'll have to double check.
Received 2,892 Likes
To get the most out of the headers.
PFADT (which is also my header of choice for the C6) does have the bung.
Also, maybe the new "locking" header bolts - prevents heat cycle/vibration loosening over time.
If not different wires, then insulators: http://forums.corvetteforum.com/c6-t...cks-boots.html
Stage 8 make the locking header bolts I think. I had a set on a car once and disappointingly they rusted. Do you know of any other brands that work well?
From my experience with other platforms( high HP Audi S4), having upgraded motor and trans mounts has alway been worth having to deal with slightly more vibrations.
Percy's makes a locking SST version, I bet ARP and Stage 8 also do.
I would then google locking header fasteners for your particular engine, and see what is available. You should have more than one to choose from.
So far I have decided on the following to go along with the PFADT headers: EE tunnel plate and Koolsox spark plug wire insulators. I'm still debating the locking header bolts.
Parts also to be installed at the same time include Sunset Orange Creations Exhaust Commander Car2U, MGW shifter, and MGW shifter box.
