View Poll Results: Will I gain HP or not ?
Voters: 20. You may not vote on this poll
To FAST or not to FAST
Need some help here...LS3 C6
Current Mods:
Intake/Exhaust/Headers (1 7/8)
Cam (230s/240s / 620's)
Makes 500whp currently..
I want to squeeze a bit more out of it so I was thinking of adding the Fast 102 and NW TB....I am getting conflicting information from various shops/tuners on if it will be worth it or not
Opinions are welcomed based on my modificaitons. I dont expect 50whp from it but I do expect 15-20whp...I will have it re-tuned if I do it.
Will I get that hp out of it or is it all a HOAX on my LS3....Thanks for all opinions/comments
Current Mods:
I don't think a different TB will make much of a difference. [just my .02]
It's not worth it. $1,000 for just the manifold, plus the money for a TB that may negatively affect your driveability. All that for 15-20whp?
That money is better spent on something else. Nitrous if you're keeping your N/A cam.
You may not see 15-20 on the top end, but the power under the curve will show the most improvements. It is a good mod and I would do it, if your intake manifold is stock. If you have already ported it, the gain/money would not be worth it.
It seems like for looks and a little bump then the FASTS is ok...not the best bang for the buck but....if you have money to burn lol.
I also want something to add something to my look under the hood...Currently its a little bland so the FAST and Fuel Rails will do that.
I dont think I want to go with Nitrous...its not a drag car and really on the street I am not sure I would use it that often.
If I could get 15-20 under the curve as one poster said then that would be great !!!
I have the FAST installed on my LS2 and I picked up around 30 under the curve and about 15 on the top end. The results on the LS3 will be a little less because of the more efficient manifold. Maybe someone who has it installed on a LS3 will chime in.
My understanding is it's a more productive mod on an LS2 vs LS3 as wiggins says... Up to you and if you want the cosmetic aspect it is a nice looking manifold. I think the TB is a waste from what I've read unless you get a ported matched set from a shop that specializes in such.... then the combined gains can be larger.
the Fast works. BUT its a $$ mod for the power. I would save that for last.
I have had it one a car and had ported stocks on others. they work like i said but its alot of money for that little extra.
