Bilstein Shocks Swaybars Review!
Old 02-19-2014, 05:16 PM
Nosferatu
Nosferatu's Avatar
St. Jude Donor '14
Default Bilstein Shocks Swaybars Review!
One "forum icon smiley" I think sums it up....
This is EXACTLY how the car should have came from the factory. I'm sure the suspension is just settling in but the handling went from crud to freaking awesome. I just put 100 miles on the new setup.
Body roll? Gone!
Can take an S-curve with confidence (and tons of fun)? Yup!
Better traction off the line because the car's stock soft suspension doesn't rebound lift in the rear? Yup!
Overall a blast. I read that the base car should do the HD (heavy duty) and the Z51/GS cars should do sport but I put the sport on the base suspension today. It's a blast. You feel a little bit more in the road but nothing crazy at all. You only notice it if you're looking for it. The steering wheel has better input and you can feel where the tires are going much more accurately.
Best money I spent. Originally bought the JOC PFADT package but they dropped the ball with endless delays. Overall, I'm a happy camper with this package it's a fine setup!
This is what it looks like...
Here's the stock rear sway bar next to the new rear sway it's down right laughable
Old 02-19-2014, 05:55 PM
CMY SIX
CMY SIX's Avatar
OMG! you invented the wheel! I posted exactly this in 07, search button is amazing!
Old 02-19-2014, 06:00 PM
Nosferatu
Nosferatu's Avatar
St. Jude Donor '14
looks like you forgot to patent it I stole your idea!!!
Old 02-19-2014, 06:03 PM
cclive
cclive's Avatar
Same here...best $500 you can spend.
Old 02-19-2014, 06:09 PM
Dano523
Dano523's Avatar
Received 3,001 Likes on 2,166 Posts
HD shocks go with the Z06 bars and Z06 stiffer leaf springs,
The sport shocks go with the Z51 sway bars and standard base leaf springs will get you by (Z51 used FE3 springs, not the FE1's springs on the base model).
Hence match sets to mimic the factory sets up of the two (factory Z06/Z51 set ups).
Old 02-19-2014, 06:45 PM
familyman's C7
familyman's C7's Avatar
St. Jude Donor '14
Way to **** on his parade.
Thanks for the post Nosferatu, like you, I got burned on the Pfadt black Friday sale. And now I'm looking for bars and shocks.
Old 02-19-2014, 07:10 PM
AORoads
AORoads's Avatar
Received 2,477 Likes on 1,940 Posts
St. Jude Donor '15
"In honor of jpee"
good reading. btw, are those bilstein sway bars?
Old 02-19-2014, 07:20 PM
Nosferatu
Nosferatu's Avatar
St. Jude Donor '14
yes this is the package I got from this shop...
http://forums.corvetteforum.com/c6-p...-and-rear.html
This is the kit they installed...
(1) 35 MM Front Tubular Sway Bar, Double Hole Kit
(1) 25.4MM Triple Adjustable Tubular Rear Sway Bar
(4) Adjustable Quiet End Links
(4) Poly Frame Mounting Bushings & Hardware
(2) Bilstein B8 Corvette Front Single NonAdjustable Shocks
(2)Bilstein B8 Corvette Rear Single NonAdjustable Shocks
Old 02-19-2014, 07:40 PM
elizavette
elizavette's Avatar
Originally Posted by familyman's C6
... I got burned on the Pfadt black Friday sale. And now I'm looking for bars and shocks.
Ive been looking as well. good thing I didn't order on black Friday, but pfadt didn't have a discount on JOC did they? I was looking into getting stage 1 shocks & sway pkg. heard good reviews about those.
Old 02-20-2014, 12:11 AM
Bedouin
Bedouin's Avatar
Eliza, start with a set of DRM (Doug Rippie Motorsports) custom valved Bilstiens for @ $425-450 w your CF discount..you very likely won't want or need sways after you install these..they're that good & still compliant enough for everyday driving.
Old 02-20-2014, 12:39 AM
*FAÇADE*
PHOTOSHOP SPECIALIST
Support Corvetteforum!
*FAÇADE*'s Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Old 02-20-2014, 11:37 AM
jbomx363
jbomx363's Avatar
I don't recall Bilstein making sway bars.
Old 02-20-2014, 11:55 AM
s'noJob
s'noJob's Avatar
Yes, apparently somebody forgot to check the forum rulebook that states once a member reviews a Corvette part, nobody else is allowed to do so ever again.
Old 02-20-2014, 01:32 PM
CMY SIX
CMY SIX's Avatar
Originally Posted by *FAÇADE*
Old 02-20-2014, 01:33 PM
CMY SIX
CMY SIX's Avatar
just pointing out THAT IF YOU DO SOME RESEARCH SOMEONE MAY HAVE ALREADY DONE THE LEG WORK FOR YOU!!!!!
Old 02-20-2014, 01:34 PM
CMY SIX
CMY SIX's Avatar
stock Z51 sways from GM call Gene culley gmpartshouse.com they come with poly bushings now, or phadt has them
Old 02-20-2014, 01:45 PM
jdk541
jdk541's Avatar
St. Jude Donor '22-'23
Thank you for posting this. I have already upgraded my sway bars. (I used the Eibach ones which look to be about the same diameter). Shocks are going to be next. Glad to hear you have experienced positive results with the Bilsteins. That is what I was considering too.
Enjoy.
To Bilstein Shocks Swaybars Review!
Old 02-20-2014, 01:52 PM
jbomx363
jbomx363's Avatar
My point is.. the OP thinks he bought Bilstein sway bars.
I bought used Z06 sways for less than the new z51's...and quite happy with them and the DRM Bilsteins.
Old 02-20-2014, 03:05 PM
s'noJob
s'noJob's Avatar
I understand. And I am trying to point out that the guy was merely using the forum to express his excitement over a new mod.
A very popular usage, so I hear, and one I hope will be allowed to continue.
Old 02-20-2014, 03:09 PM
Nosferatu
Nosferatu's Avatar
St. Jude Donor '14
correct they are not Bilstein but part of this package. They work well with the setup.
Quick Reply: Bilstein Shocks Swaybars Review!
