Looking for Thread "C6 brake job instructions & piston push back using a screwdriver
Two months ago I found a thread on the forum which explains how to push back the brake caliper piston with a screwdriver, caliper frame & the brake rotor as leverage. I searched the forum and I can not find it. I want to send the information to another C6 corvette owner with instructions on how to change there own brakes.....
Reggie saying....Fix a friend's brakes on a C6 and he saves money and you have a new headache for a day. Teach a man to fix his own brakes on a C6 and he can eat fish and work on his car for a lifetime.
pad change takes about 5-10 mins per set once you get the hang of it.
I recommend hitting up youtube to see examples...in fact there is some vette videos for pad changes.
This is not for me. I wanted to pass the information on to the other corvette owner.
I was trying to find the post which contain pictures of a guy using a screwdriver to open up his calipers instead of using a c-clamp. The pictures will show him how simple it is to change his own brakes.
I will search YouTube for C6 brake instructions and paste the link in this post for others. Hopefully someone can add to this post the link showing the member using a screwdriver instead of a C-clamp.
The screwdriver is 100% faster.
Received 2,061 Likes
Two flat blade screwdrivers and done in 10 seconds.
Found it under FAQ by "JoeG"
http://forums.corvetteforum.com/c6-t...rake-pads.htm
Once you use this screwdriver method, you will never use c-clamp again.
Thanks JoeG...Great idea..
1 Post
http://forums.corvetteforum.com/c6-c....rake-pads.htm
I do not want to recommend processes that can damage a vette owner's car. If you look at the 2 locations the screwdrivers are applying pressure, I can not see how you can cause damage. Did you bend your rotor and/or caliper? Please explain. Thanks..
Not sure what you mean by "No you will bend the caliper or rotor". then you end your comment with "screwdriver much easier".
1 Post
Not sure what you mean by "No you will bend the caliper or rotor". then you end your comment with "screwdriver much easier". I do not want to recommend processes that can damage a vette owner's car. If you look at the 2 locations the screwdrivers are applying pressure, I can not see how you can cause damage. Did you bend your rotor and/or caliper? Please explain. Thanks..
But like anything it all depends on your technique!
I was using sarcasm.... when turning wrenches creative solutions often work well. I had hoped that it was obvious that a screwdriver would generally NOT damage rotors or calipers given the job the brakes have to do.....pretty safe bet the screwdriver would be the weaker link. Really what might damage ones car is the "human" that fails to consider the potential outcome of their actions.
1 Post
ummm I'm not sure...not willing to try it...these are aluminum...maybe on some cast steal ones you'd be find...these things strip out easily...so odds are they are softer than you think. The force from the pistons is distributed nice...not sure I want to pry a hard forged screwdriver against mine... (just me)
With the vette I live on the edge as I even drive mine in the rain...
