★ Protect Your Paint! ★
Premium Supporting Vendor
Its Not If, Its When...... It only takes one chip to ruin a perfect day!
For 20 years, Cleartastic has been providing the #1 "Do It Yourself" Paint Protection Kits!
Quick, Simple To Apply, Easy On Your Wallet! While your C6 Gen's paint is beautiful, its also delicate & vulnerable. Between your own tires throwing stones back onto your paint and your front end exposed to oncoming debris, it’s only a matter of time before that one chip ruins your perfect day.
Cleartastic paint protection film addresses those 2 issues without changing the look of your corvette..
Cleartastic & Cleartastic Plus is a clear flexible film that creates an invisible barrier between your beautiful delicate paint and rocks & debris. Pre cut & designed for a simply easy application.
The kits come pre cut. We personally designed these kits knowing the enthusiast probably has no experience working with protection film. So the application is easy and the fit is perfect. More important, you apply it so you don't have to drive to another venue and have a stranger all over your car! Our kits save you time, money, stress and of course your paint!.
★ Our film is extremely flexible which allows for an easy install.
★ It also has "self healing" characteristics which means some small marks, nicks will vanish over time!
★ Superior optical clarity. Goes on crystal clear to create an invisible barrier and allow your beautiful paint to come through.
★ Extremely tough to withstand rocks, road debris and human abuse.
★ We personally designed these kits! They where made for the enthusiast who has never applied paint protection film before
★ Don’t accept cheap imitations with false claims. Cleartastic has been protecting paint for almost 20 years. ...a name you can trust.
________________________________________ ___
05-13 Base Cleartastic Kit# 70
Behind Front & Rear Wheels Plus Lower Rocker
Cleartastic creates an invisible barrier protecting your delicate paint from those meaty tires.
Rocks and road debris can get around mud guards/flaps. Cleartastic is placed right on the painted area you want protected!
It even protects the painted area that wraps into the wheel wells.
Cleartastic has no adhesives. Our special formulated cling prevents paint chips, withstands harsh weather and high speeds. Wash right over them. Pre cut & designed for a simply easy application. Applies in minutes. Invisible once applied! Removable and reusable.
Retails for $69.95. On sale $60.95
Click here to read more & securely order: http://store.cleartastic.com/c6set.html
05-13 Base C6 Cleartastic PLUS #78
Front Nose Paint Protection kit
Cleartastic Plus DIY nose kit, creates an invisible barrier protecting your delicate paint from on coming rocks, bugs & debris. Cleartastic Plus prevents paint chips, stains & withstands harsh weather and extreme high speeds.
Cleartastic Plus has a mild adhesive to make it a “set it and forget it” film. One time application provides years & years of protection.
Pre cut & designed for a simple easy application. Smooth as glass appearance make it invisible once applied. Wash & wax over the film. Treat it like your paint.
Retail $164.95 . On sale now $148.45!
http://store.cleartastic.com/c6clplfrnopa.html
06-13 GS & Z06 Cleartastic PLUS Kit #80
Invisible Front Nose Paint Protection
Retails $174.95 On Sale On For $ 157.45
http://store.cleartastic.com/06gs42z06zr1.html
06-013 Gs, Z06 & ZR1 Cleartastic PLUS Kit #77
Upper Rear Fender Paint Protection
Your upper rear fenders are sticking out & exposed to oncoming debris. Cleartastic PLUS prevents damage by creating a clear protective barrier.
It protects against, scratches, rocks & road debris. Cleartastic Plus has a mild adhesive to make it a “set it and forget it” film. One time application provides years & years of protection. Pre cut & designed for a simply easy application. Applies in minutes. Smooth as glass appearance make it invisible once applied. Wash & wax over the film. Treat it like your paint.
Retails $59.95 On Sale For $53.96
http://store.cleartastic.com/z06refeflpap.html
Body Protection Kits
Cleartastic Plus DIY Kits create an invisible barrier protecting your delicate paint from those meaty tires. Cleartastic Plus prevents paint chips, stains & withstands harsh weather and extreme high speeds.
Rocks and road debris can gets around mud guards/flaps. Cleartastic is placed right on the painted area you want protected.
Also helps with your rear brake duck getting pounded!
Retails $129.95 On Sale For $116.96
Click here to read more & securely order for the Grand Sport:
http://store.cleartastic.com/c6z06kit.html
Click here to read more & securely order for the 427 Vert & Z06:
http://store.cleartastic.com/z06427co.html
06-13 GS & Z06 Cleartastic PLUS Combo Kit
Combines Upper Rear Fender & Body Kit At A Better Price! (and on sale!)
Retails $184.95 On Sale Now For $149.35
http://store.cleartastic.com/z0427cocokic.html
Cleartastic PLUS
Bulk Film 6"x72" or 12"x28"
Protect your Corvette or any make and model vehicle’s paint from rocks & road debris with Cleartastic Plus bulk roll film!
Great for protecting Side skirts, the rear upward panel of the Zr1 side skirts, front splitters, spoilers, door sills (dragging feet) ........anywhere you think your paint is vulnerable!
http://store.cleartastic.com/clplfiinburo.html
Feel free to contact us with any questions! 1800 778 9898
Thank you!
Tough as nails.
Its hard to get a picture of a film designed to be invisible, but here are some pictures, some sent in by Corvette Forum members.
Here are 2 shots of the C7 mirrors (It doesn't get much closer..)
http://forums.corvetteforum.com/atta...astic-plus.jpg
C6 GS Nose Kit#80
Rear upper fender protection kit #77
Front duct and lower rocker Kit#76
Rear brake duct kit #76
Hope that helps
C6 GS Nose Kit#80
Hope that helps
__________________
Number 1 "Do It Yourself" Protection Kits Since 1996
*Serving The Corvette Forum Members For 20 Years!
*Invisible Once Applied
*Tough As Nails Protection
*Saves You Time, Money & Of Course Your Paint
*Proudly Made In The USA
CHECK OUT OUR NEW WEBSITE! http://www.cleartastic.com
Orders are shipping!
Any questions about our products please contact us!
Thank you
Thank you
Spring is in the air..... and so are rock and road debris!
Protect It With Cleartastic Pre Cut Invisible Paint Protection Kits You Easily Apply Yourself!
Cleartastic Kit 70
06-13 GS, 427& Z06 Invisible Front Nose Paint Protection
06-13 GS, 427, Z06 & ZR1 Upper Rear Fender Paint Protection
Grand Sport & Z06 Body Protection Kits
Cleartastic PLUS
Thank you!
Shipped a ton of orders last Thursday & Friday. Expect the man in brown to be knocking on your door soon Any questions about your order, feel free to contact us
Thank you!
Thank you!
