Manual transmission and rear differential fluid change
Hey everybody, I know this has been posted previously and also there's a sticky in the FAQ section for DIY, but I just wanted to see if there was any kind of update on fluids. What are you guys using to replace the transmission fluid and the rear differential?
I don't believe there has been any sort of update regarding fluids recently.
I went with Redline D4 ATF in the manual transmission and GM Dexron LS fluid in the differential since it is synthetic and already has the correct amount of friction modifier in it already.
