2008 Corvette NAV but no XM
5th Gear
Hello, I have a 2008 Corvette with nav, but no XM.
http://www.corvettemuseum.org/specs/2008/index.shtml
The link above says "OnStar and XM Satellite Radio standard on all models"
I have OnStar.
Is there a special code/button combonation to get the XM to show up on the radio?
I have OnStar.
do u have that big black xm antenna on your roof ? if so u have xm radio but probably need it activated
5th Gear
When the XM box is plugged into the NAV unit, then it will show up as a source choice on the screen. If the XM box is not there, not plugged in, or not powered (12v) then it will not be a choice on the screen. The XM box is located behind the waterfall (the real waterfall) in my Vert. I'm not sure where it is located in a coupe. A coupe owner will chime in, then you can look and check it.
5th Gear
5th Gear
