Guys with side skirts - pebbles stuck between body and skirt?
Old 03-29-2014, 09:44 AM
intheboost
intheboost's Avatar
Default Guys with side skirts - pebbles stuck between body and skirt?
Anyone here have a fix to avoid the pebbles that get stuck in between the small void between the ZR1 style side skirts and lower rocker below the door?
Old 03-29-2014, 10:08 AM
ROBMARZ
ROBMARZ's Avatar
Originally Posted by intheboost
Anyone here have a fix to avoid the pebbles that get stuck in between the small void between the side skirts and lower rocker below the door?
Don't drive in the rain. After a long road trip last year the groove near the real wheels were full of sand - not really pebbles. Power washed and picked the last our with a plastic fork tine.
Old 03-29-2014, 10:24 AM
AtomicZ_Eric
AtomicZ_Eric's Avatar
I haven't found a good fix to prevent the pebbles yet. Occasionally I take out the screw near the wheel and gently pull the 1/4 panel outward about 1 cm. Very easy to remove the pebbles.
Old 03-29-2014, 10:28 AM
intheboost
intheboost's Avatar
Thanks guys, I clarified my post. I have ZR1 side skirts and the pebbles get stuck between these skirts and the lower rocker panel where they attach. I was able to do the DIY regarding the rear quarter panel area. I am going to get the Apsis type splash guards for the front fender, but I still think they will find a way in there.
Old 03-29-2014, 10:36 AM
whit1
whit1's Avatar
I haven't come across the issue yet. But I may just put some clear plastic film along the entire run of skirt or some very thing rubber molding/gasket
Old 03-29-2014, 10:37 AM
DUMAN
Support Corvetteforum!
DUMAN's Avatar
St. Jude Donor '10
In over 2 years I have 0 issues with pebbles/rocks between the body and skirt.
EVRose
EVRose's Avatar
I have those side skirts. Mine doesnt have any gaps for rocks to get stuck in. They are flush tight against the rocker panel all the way across.
To Guys with side skirts - pebbles stuck between body and skirt?
Quick Reply: Guys with side skirts - pebbles stuck between body and skirt?
