Recycle air button
Recycle air button
Does the c6 recycle air button let in air or no? Every other car I've owned let noticeable (through the vents) air in so that when I didn't want the A/C on but was a little hot that would cool it down.
I bought a used c6 and haven't noticed any air coming in so I'm wondering if it's an issue or that's just the way it is
If you're talking about the recirculation button, 2nd button from the left, while it's lit, no outside air is coming in.
When you press that button and it lights up, it not only keeps the outside air out, it also turns the fan up a notch (if the system is on). If the system is off it will effectively keep any air from moving into the cabin. When that button is not lit, it allows the outside air to be force -fed (at a verrrrry small amount) into the cabin depending on the speed of the car, even when the system is off. When the system is on, it allows fresh air into the cabin at the fan speed.
lisa
lisa
lisa
lisa
I've only had cars with manual A/C controls before and those would let the air in at whatever temperature the controls were set at. Not sure how it works with digital/electronic controls
Correct, if the recycle button is not lit, it still lets some outside air in. Usually at the temp that was set when the system was shut down. For example: if the temp inside was set at 90 and you turned it off, it will still feed hot air, and when you find that your feet are burning up, even though the system is turned off, you will need to turn it on and turn the temp down. Let it engage enough that the fans start and then you can turn it off at the new set temp. It will then feed the new cooler air to your feet, or wherever you have it turned to, at a force that is dependent on the speed of the car.
lisa
lisa
The C6 climate controls will not let you just draw in outside air without adding either heat or cooling to it. Very few cars now days will let you pull in untreated outside air.
lisa
lisa
Got ya. That's what I want - outside air coming in at whatever temperature it's set at (so I don't always have to turn the A/C on) - but it seems to be not working
You aren't going to get noticeable airflow through the vents with the system off, if that is the question you are really asking.
Which doesn't negate what I said earlier. lol
lisa
lisa
You could have a clogged up cabin filter. I bought my car with 60k miles, and it looked as if it had never been changed. New filter made big difference in air flow.
Received 2,051 Likes
St. Jude Donor '13
Received 2,061 Likes
Another important function of the RECIRC button is to prevent warm air from coming out of the vents in the footwells in the summer. This is very noticeable when it is warm outside and the top is down or the roof panel is out.
