Airbag light
Before you do anything notify the NHTSA and file a complaint. It's the only way we will get a recall.
http://www.nhtsa.gov/Vehicle+Safety/Recalls+&+Defects
Thanks for that - very helpful. Like I said it has only happens a couple of times which has not worried me. Does it usually get worse? If the light is on does it mean the bag is disabled, or is it just the wiring that is at fault and the bad is still working? I live in Dubai and the driving here demands that the bag works!
David.
David.
We need to get some publicity on this Vette air bag issue while the media and the politicians are hot of scapegoating GM and get them to recall them and replace the connectors. Anyone got any connections to media or politicians on the Congressional committee?
Soldering the connections is not an option...
My light tends to come on after a hard turn, hard stop, or hitting a pot hole. I can image the light would come on during a crash.
I am working with a Michigan reporter on our issue. It is going slow but I hope something happens as a result of it.
Received 1,497 Likes
No-IL Events Coordinator
C6 of Year Winner (appearance mods) 2019
2018 C6 of Year Finalist
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Just had mine repaired, "frayed" wire between back and seat bottom. And yes, I made a report...
I haven't had any airbag light problems with my 05 but the guy I bought it from did tell me the air bag light was on an they needed to fix it before they shipped it he said It was a connector under the driver seat
its a little strange an kina scary not having any warning lights on the dash iv done all the repairs an the car is running flawless but every time I drive it im looking waiting for some warning light to pop on
IIRC if/when the light is on the bag(s) will not deploy, so...
I had this issue a couple of days after purchasing my 2010 GS Vert. In my case, I removed both seats, checked the wiring and found no issues. Next I checked the connectors and found the driver's side female connector had two (2) of its sockets spread out further than the others. I was able to squish them closer together and then plug in the male connector and zip tie them together. The air bag light has stayed out ever since.
Another suggestion I saw in a previous post and performed - don't use an exist setting that moves the seat (if you have memory seats). This cuts down on seat movement and thus the potential for loosening the airbag connectors over time.
Hope this helps anyone experiencing this issue!
The air bag light in my vehicle is currently "on" but I recently upgraded my interior and both seats were out of the vehicle. I hope the connector was not damaged during the process.
Mine came on a couple of times about a year after I bought the car. It was intermittent like yours. I was in the dealership (like having root canal) for several minor issues I didn't want to mess with. The light had not been on for a couple of weeks and 1,000 miles but they said they repaired the connector in the driver's seat under warranty. The light has never come on again.
