Is there any downside to painting the wheel barrels?
So I painted (G2) the calipers and detailed the wheels & wheel wells on my yellow vert last week. I taped one of the wheel barrels with black tape to see what it would look like on my car. The black barrels made the chrome wheels pop much more than the stock grey.
Due to my tiredness and soreness, I didn't paint them at that time. but I'm thinking about doing so. But I wondered if there is any negative aspects to painting them? Does the paint adhere well? Are they more problem in keeping clean? Do they look worse when dirty? I know that many have painted their barrels. What negative experience, if any, have you had? Would you recommend painting them?
Thanks. I didn't think about using plastidip. Would that hold up to cleaning though?
Twice a year previously, I would have to take acetone on a rag to really scrub them out to make them look new again, and that meant taking them off the car to do it.
I also used the G2 on my calipers last year I striped my rear wheels put a good coat of wax on they are very easy to maintain this year when I did my calipers I striped the fronts and again put agood coat of wax on they clean real easy because You now have a smooth surface as opposed to the rough gray paint Jack
Received 2,837 Likes
2021 C6 of the Year Finalist - Modified
I painted mine black with the Dupli-Color brake caliper paint. I rolled it on and use a brush....looks great with the chrome wheels and that's the look I was after.....Won't know how they hold up until after the season......should be easier to clean and touch up if needed....
Not all that tough. Make sure there is plenty of ventilation wherever you are using the stripper and acetone though. I purchased Kleen Strip brand Aircraft Paint Remover in a metal quart can from O'Reilly's and their rubber gloves. Kleen Strip brand Acetone from HD. One can each will do all four wheels. Less than $20 for both cans.
It took a second coat to really get them completely stripped and I spent about an hour on each wheel to strip it, and do the acetone wash as described in the DYI thread that I had followed.
I found the thread and re-posted it for you and other members thinking about doing it, and a BIG thanks to the member who created the thread...
I paint mine black about two months ago and very happy with the results. The only down side is the black shows dust.
This is something I'm wanting to do - my barrels look horrible...and the gray paint is bubbled up in some spots. I'm wondering about the wheel balance. Would it be best to just pull the weights, strip, paint and then take them to the tire shop for a re-balance? Or something else entirely?
I plastdip my barrels black and it has held up all winter. I plan on peeling and "dipping" them in a few weekends. I highly recommend it and if you don't like them you can just peel it off
