Headlights stopped working…
When I went to leave work yesterday, my headlights were not working. Whether I put the car in auto or manually turn on the lights, the dash lights up along with taillights, but the headlights don't work. The IBM's will work, but the low beams won't light up. I checked the fuses for the low beams, and I also tried replacing the relay for the low beams. I would find it very hard to believe that both headlights burned out at the same time. Any ideas where to check next?
The cause is likely the fuse box under the hood being "bad". "Bad" is in quotes because it's most likely poor design rather than just a random failure. Check out this link for more info.
http://forums.corvetteforum.com/c6-c...eadlights.html
Mack
Mack
Mack
Mack
Thanks for the link. Yup, bad fuse box. Already out and halfway disassembled.
