Fast turn signalso
Fast turn signalso
First I've had the issue of turn signal stopping - hit hazard switch then OK.
Last week I replaced the third brake light then the drivers side turn signal blinked fast, so I changed ALL the bulbs front and rear. Both signals blinked fast - so I replaced the hazard switch, getting good at removing stuff to access. No change in signal speed, could I be chasing a bad ground?
2000 conv
2000 conv
Received 2,882 Likes
Wrong forum, this is C6. Are all bulbs working? mine flashed fast when a bulb was out.
