TPMS Failure
TPMS Failure
Got in the car to take the wife on a short road trip on a beautiful day and the low tire pressure light came on. The DIC said "right front tie low air pressure. I cleared the message and the DIC showed 16 psi in that tire.
I got out and manually checked the tire pressure in both front tires. Both showed 31psi. I checked the rears and they showed 31psi as well. The "Low Pressure in right front tire" message kept popping up in the DIC.
Has anyone else had this problem? I assume it may be a bad sensor. Car is a 2013 Gran Sport Coupe, 3LT, F55, NPP, ETC. recently had the airbag light come on for a couple days and then go away with no action by me.
Thanks in advance for your advice. Hoping to not have to take it to a dealer.
BobD
BobD
Received 2,049 Likes
St. Jude Donor '13
A local club member had endless TPMS problems which the dealer could not fix, until he unplugged his Iphone charger in the car. No problems since then.
But sensors do occasionally go bad.
