back up (reverse) lights not working.
My back up lights are not working in my 2008 base M6. Checked all fuses and bulbs seem to be good as they light up when I unlock the car. Ive searched and only found info on this issue in the c5 section. I ordered a replacement switch for my M6 tranny but before go through the work of replacing it I figured I would check to see if im missing anything. Anyone have this issue? Find it very annoying that a back up switch would go with only 26k on it.
Mike
2008 C6 Corvette- jet stream blue, black spider replica wheels, blacked out tails, lowered, corsa sport exhaust, headers, air raid intake,
Nitrous Outlet plate kit 150 shot, tune.
2005 GTO with home made custom twin turbo kit 586hp 604tq. SOLD.
1995 Trans Am LT1 SOLD
Mike
Switch is easy to check with a Ohm meter.
Out of reverse/ball out, meter should read zero .
In reverse/ball pushed in, should show resistance.
The only no fun part is getting under the car to pull it/ to check it.
I guess I was just hoping there was some other stupid cause/easy fix I was unaware of.
