Blacked out my side markers with LED
Going for a little cleaner look. Easy mod. and goes pretty well with my Eagle Eye LED tail lights.
Before:
After:
Before:
After:
They are not difficult but wear a long sleeve shirt or you will cut the hell out of your forearms. For the rear you access them through the outside tail lights. The front is accessed by removing the under panel behind the headlights inside the wheel well. Easier access if you remove the front wheel. On the back of the lens housing are two tabs that you expand with your hands to push them out of the fenders. This can be tricky because as you get one clear, the other pops back into place. When you finally get one, the others seem to go much easier. Just gotta take your time.
Received 2,887 Likes
Looks great!
Looks good.
Actually I did not even remove the front fender liners. The lenses come out so easy all I had to do is push on the front which lifted the rear and then with some finesse they pop right out. Once you remove the rears via the tail light opening you will see how they are attached and it makes it easier to take off the fronts.
Any pics of the black light bulbs.
