Got a chance to line up with a GT-R...
Old 04-28-2014, 12:16 PM
Dano523
Dano523's Avatar
Received 3,007 Likes on 2,169 Posts
Rolling runs are meaningless (not driver talent needed).
On a strip, as well out of a tight benders on a circuit track, you still need to dig out the hole and these few second every corner add up to mins in the end of a full timed race/seconds per run on the strip.
Lets face it, Zero to 60mph times now are not based on HP anymore, but the cars ability to dig out of the hole with the traction that the car has instead. Even with dropping a E force on vet, your not going to lower the 0-60 time number down much, due to the lack of over all traction that the car has out of the hole (even when running super comps).
So even on a ZR-1, the 0-60 is 3 second plus, while a Veyron Black is in the 2.5 second mark instead.
Old 04-28-2014, 12:30 PM
x88
x88's Avatar
Are we talking a base model vs GTR? In that case, what's the point? Maybe I'm missing something here, what are your mods?
Old 04-28-2014, 12:49 PM
GOLD72
GOLD72's Avatar
Received 1,103 Likes on 717 Posts
Originally Posted by dvilin
Those GT-R's are definitely tough to hang with. They have the AWD that launches them like a rocket and then they keep on pulling. You gave it a shot and like you said you need a bigger gun.
Hard to beat a high power car with all wheel drive. You would have lost to a 911 Turbo in a short sprint from a standing start as well.
Old 04-28-2014, 12:56 PM
veloz
veloz's Avatar
Originally Posted by Boomer111
Gotta pick your fights better.
words of wisdom right there..always be prepared to just walk away..better for them to guess maybe they could have won than know for a fact...
Old 04-28-2014, 01:29 PM
vray
Support Corvetteforum!
vray's Avatar
I read that he 2015 GT-R is supposed to be capable of a 2.0 second 0-60 !!
Old 04-28-2014, 01:56 PM
Nosferatu
Nosferatu's Avatar
St. Jude Donor '14
Reading comprehension > you
I'll snippet that part for you right here...
Originally Posted by Nosferatu
Both runs from a roll to eliminate traction being a factor in the outcome and just seeing raw power who's got more.
I explicitly stated taking traction out of the question the rolling runs were to see which car flat out, has more power. Get your panties out of a bunch.
Rolling runs are fun and if you're a stick shift (like myself) you have to have some driver skill to row gears quickly and accurately.
Anyways, at the track I've ran my car and I have beaten faster cars that should take me. On the flip side, I've also lost to cars I should have beaten. It happens and is part of the fun.
Old 04-28-2014, 03:22 PM
Dano523
Dano523's Avatar
Still not about power, but traction instead.
Not sure what HP your car is making, but on mine, if I stomp it to achieve WOT, I'm going to break the tires loose well into third gear until I get enough down force to start rear down force pinning the super sport rear tires down to stick instead.
To see this yourself even with a stock motor car, go into Torque management with a tuner, and de-crippler the motor across the board, then crispness/quicken up the pedal to TB response.
You will be surprised what GM did in torque management even in full-off mode to try to save the drive line to cut way back on warranty work. Not only did they get creative there to hobble the motor, but also in pedal to throttle body response as well.
Old 04-28-2014, 03:55 PM
Crowhater
Crowhater's Avatar
Well if it makes you feel any better I take great joy in beating GTRs. This Powerfabs modified shop GTR with Powerfabs go to driver. My car is set up to run 1/8 mile not 1/4 mile so I was at a disadvantage but he still could not run me down. This is also with my last engine the 416 not my new 427.
Old 04-28-2014, 04:10 PM
Crowhater
Crowhater's Avatar
I read a bunch of the post on this thread and I must debunk some of it. If you know racing you can win most of the time with a car that has much less power. Spinning is not winning, so spend your money on what matters "traction". When at the track I am more concerned with my competitors tires and suspension than anything else. I have a pretty good idea how much HP the track can handle after 1 pass with my setup. If a guy comes up with a 1000rwhp car and 19" drag radials I will take that race all day and tell him he can use his goofy gas also. There is no away he will plant that power on that sidewall and get a 60' that is worth a darn. If I cut a 1.35 - 60' and he cuts a 2.3 - 69", he has just given up a second at the start and in a 6.3-6.4 second race he does not have enough track to catch me. It all comes down to MATH.
Give me a bone stock C6, LS3 auto, 275/45-17 hoosier D/R , change the rear diff to a 3.42 and add a 3500rpm stall, this set up will skin 60% of the daily drivers that show up at the 1/8 mile. Take out the passenger seat for another 1/10.
Old 04-28-2014, 04:20 PM
JAsVette
JAsVette's Avatar
St. Jude Donor '14-'15-'16
You must be a gluten for punishment! Why even bother to go up against him? That's like a jogger going up against a World Class Sprinter in the 100 yard dash! You know you're going to get your jock handed to you. The GT-R is a $100k sports car! It better be faster than a production Vette! That guy had nothing to loose by racing you and he knew it. I had a 370Z and though its not a GT-R, the looks are similar but the power not so much! With my 370Z, I once went head to head with a 5.0 and he had my lunch which was stupid of me to even think the Z had anything over a 5.0. I still remember how crappy I felt after that. Lesson learned! I would take the overall package of what the Vette has to offer any day over a GT-R including looks and interior and I'll still have enough money left for groceries!
Old 04-28-2014, 04:32 PM
Allan
Allan's Avatar
St. Jude Donor '14
GT-R v. 2013-427
Now who wins?
Old 04-28-2014, 05:22 PM
ProfessorDeath
ProfessorDeath's Avatar
St. Jude Donor '13-'14
Originally Posted by Allan
GT-R v. 2013-427
Now who wins?
The GT-R.
Anyway, I hate to see arguments started in a thread that was meant in good fun. Yes, my Corvette is a base model. It wouldn't have mattered if I'd shown up in a Z06 or a ZR1 or a Lingenfelter. We raced from a stop light to about 90mph, because it was fun and no one else was around. Simply put, we felt like it.
As to why line up with him? He pulled up next to me in the middle of the night, empty highway, light turned red. Seemed like the perfect opportunity, and when I looked over and saw him grinning, we both knew what was about to happen. It's that "why bother?" attitude that keeps people from success. If no one ever seized an opportunity, this would be a pretty boring world we live in. Fortunately, this was just a drag race and not a career choice.
Old 04-28-2014, 05:52 PM
  #33
LMB-Z
LMB-Z's Avatar
Originally Posted by ProfessorDeath
The GT-R.
Congrats to the OP. I think you have some large knads. Takes guts to do what you did, knowing what the outcome was probably going to be, but still all in fun.
Old 04-28-2014, 08:21 PM
  #34
Lerxst
Lerxst's Avatar
Originally Posted by z edge
GTR are fast as hell and honestly they could probably run circles around me I don't even care they are uglier than they are fast, looks like a toilet on wheels.
Totally agree. I don't care how fast they are they're still rice burners with a fart can! Stick to the American muscle!
Old 04-28-2014, 08:29 PM
  #35
Mad*Max
Mad*Max's Avatar
Received 1,496 Likes on 816 Posts
I guess I'm lucky I didn't have to see the taillights of an Audi RS4 this once from a traffic light
Old 04-29-2014, 12:20 AM
  #36
ProfessorDeath
I think the looks of them are sharing to grow on me...
Old 04-29-2014, 03:20 PM
  #37
JAvery20
JAvery20's Avatar
Run anything that comes up next to you. I ran a modified GTR back in November at the track. Fully planned on getting wiped out.
But somehow have the white slip after that run. He trapped 135 and was freight training me but I put a half second on this guy at the 60ft. 1.91 to his 2.43. No idea what happened, he spun, he stalled, he fell asleep, but always give it a shot.
For people that say one sports car stands no chance against another, I don't think you've raced enough.
To Got a chance to line up with a GT-R...
Old 04-29-2014, 04:02 PM
  #38
ProfessorDeath
Originally Posted by Bedouin
Lots of speculation about what's fastest, but this Laguna Seca fast list ends the debate with the Nissan GTR in 15th place... well below the 5th place C6 Z06's 1:34 time;
- from Car & Driver;
"Ah, the Corvette. No car (save the Cayman R) generated more controversy at this year's (2011) Best Driver's Car, and no car will generate more controversary once you commenters take your gloves off. Let's get this out of the way right now: The Z06 decimated the competition around Mazda Raceway Laguna Seca. The devilish Chevrolet, which showed up with 666 miles on the odometer, was more than a second faster around the track than the second-place Ferrari 458 Italia, and faster still than every other contender. No car was even close to the time laid down by the LS7-engined monster, despite the fact that the Fezza, the Lexus LFA, the Audi R8 GT, the Mercedes, and the Nissan GTR all packed more horsepower."
Lap times (96)
Pos Make / Model Time Speed (km/h) Year Power (hp) / Weight (kg) Driven by
1. SRT Viper TA 1:33.62 139 '13 649 / 1520 Randy Probst
2. Chevrolet Corvette ZR1 1:33.70 138 '08 647 / 1530 Randy Pobst
3. Dodge Viper SRT-10 ACR 1:33.92 138 '08 600 / 1536 Chris Winkler
4. SRT Viper GTS 1:34.23 138 '13 649 / 1560 Randy Probst
5. Chevrolet Corvette Z06 Z07 Package 1:34.43 137 '11 512 / 1394
6. McLaren MP4-12C 1:34.50 137 '10 600 / 1434 Randy Pobst
7. SRT Viper 1:34.63 137 '13 659 / 1520 Randy Probst
8. Mercedes SLS AMG Black Series 1:35.03 136 '13 631 / 1550 Randy Pobst
9. Devon GTX 1:35.08 136 0 659 / 0
10. Lamborghini Aventador LP700-4 1:35.40 136 '11 700 / 1575 Randy Pobst
11. Porsche 911 GT2 RS 1:35.56 136 '10 620 / 1370 Johannes van Overbee
12. Chevrolet Corvette ZR1 1:35.80 135 '08 647 / 1530 Randy Pobst
13. Ferrari 458 Italia 1:36.22 135 '09 570 / 1485 Randy Pobst
14. Nissan GT-R 1:36.30 135 '12 550 / 1736 Randy Pobst
15. Nissan GT-R 1:36.35 135 '11 530 / 1736
16. Lexus LFA 1:36.39 135 '10 560 / 1609
17. Audi R8 GT 1:36.39 135 '10 560 / 1520
18. Nissan GT-R 1:36.63 134 '12 550 / 1736 Randy Pobst
19. Porsche 911 GT3 RS 1:36.77 134 '10 450 / 1400
20. Porsche 911 Turbo 1:37.80 133 '09 500 / 1570
21. Ferrari F12 Berlinetta 1:38.04 132 '12 740 / 1725 Randy Pobst
22. Chevrolet Corvette Stingray 1:38.28 132 '14 461 / 1577 Randy Pobst
23. Chevrolet Corvette ZR1 1:38.70 131 '08 647 / 1530 Car and driver
24. Ford Mustang Shelby GT500 1:38.70 131 '13 659 / 1750 Randy Pobst
25. Audi R8 V10 plus (2013) 1:38.70 131 '13 550 / 1570 Randy Pobst
26. Mercedes SLS AMG 1:38.82 131 '10 571 / 1620
27. Mercedes C 63 AMG Coupe Black Series 1:38.90 131 '11 517 / 1748 Randy Pobst
28. Porsche 911 Carrera 4S (991) 1:39.00 131 '12 400 / 1465 Randy Pobst
29. Chevrolet Camaro ZL1 1:39.18 131 '12 588 / 1838 Randy Pobst
30. Porsche 911 Carrera 4S (991) 1:39.19 131 '12 400 / 1465 Randy Pobst
31. Porsche 911 Carrera S 1:39.30 131 '11 400 / 1415 Randy Pobst
32. Ford Mustang Boss 302 LS 1:39.50 130 '12 443 / 1652
33. Porsche 911 GT3 1:39.52 130 '06 415 / 1395
34. Porsche 911 Turbo 1:39.89 130 '06 480 / 1585
35. Porsche 911 Turbo S 1:40.11 130 '10 530 / 1585
36. Audi R8 V10 5.2 FSI 1:40.20 129 '09 525 / 1620
37. Nissan GT-R 1:40.45 129 '08
This is fantastic and all, but we ran straight line stop light to stop light.
Old 04-29-2014, 08:54 PM
  #39
Purdue
Purdue's Avatar
I'll take one in a heartbeat.
Old 04-29-2014, 10:12 PM
  #40
bucwheat
bucwheat's Avatar
Ran one several years ago in a 2009 Z06 with headers and cold air intake,I out run him but it was all I could do to get away from him,if I didn't know how to launch he would have the edge.
Quick Reply: Got a chance to line up with a GT-R...
