magentic ride control - with vs without???
I am looking to purchase a 2012-13 Grand Sport convertible and I have a question for you guys that know a little about the ride with AND without the magnetic ride suspension. I am looking to spend the least amount on my car....it is just my weekend car and I am set on a 2012-23 because of the seats and the upgraded bose from previous years. But, my main question is what is the difference of a vette with and without the magnetic suspension. I really only want a "touring" car....I am not going to track it....i just like the looks of the C6 and I figure the price point is perfect for me with a 2lt. I could care less about the heads up display and all the other options on the 3lt/4lt. So my main question is this....."If a vette with the magnetic suspension is in tour mode or sport mode, how will a NON-magnetic suspension compare? If I would say that a vette with a magnetic suspension rates a "1" with the firm feel in SPORT mode and a "10" in the TOUR mode....where would the feel be without that option altogether? Is the non-magnetic suspension more firm or more cushy for cruising? ON a 1-10 scale ("1" being firm) what would you say? I know the magnetic suspension has more things going on than jsut the feel of the ride as I have read on other posts, but seriously this is just a drop-top for me to enjoy on the weekend cruising.and I want it more because of the looks and being able to jump on it once in a while for a thrill.
So again.....1-10 what would you rate the non-magnetic vette on terms of a touring ride (1 being firm and 10 being cushy compared to a magnetic-equiped vette).
Thanks in advance for your responses.
I would say the a C6 without the Magnetic Selective ride would be fairly soft (towards a 9-10 on your scale).
From your description of what you are looking for, I think you would probably be fine with the non F55 suspension.
I have the F55 (Mag Ride) and usually leave it in Sport Mode though. Actually on a smooth road you wouldn't be able to tell the difference.
For a weekend car, no tracking, I would get the mag ride. However, they are expensive if leaking or failed over a standard shock.
When my wife is in the car if for some reason I left it in Sport she would not feel the difference on the highway. The local roads might be different. I think "Tour" and the standard suspension are about the same.
I think you have answered your own question though spending the least amount would not include the F55 regardless. The HUD on the other hand I find is indispensable. Best of luck in your search hope you find what you are looking for.
Get it without. You can tweak the GS, with better sway bars and shocks and not have to worry about expensive mag ride system repairs in the future. I had a choice and went simple.
I started with a base car with the F55 and have converted it to a wide body (including springs, sways, and Z06 brakes). The base with F55 is very comparable to the GS with F55.
BUT, the base without the F55 would be much softer riding than the GS without F55, since it would come with Z51 shocks.
Therefore I believe that a GS with F55 would have a slightly better ride than a GS without the F55 suspension.
To the OP again, get it without. Not worth it.
It doesn't. I've driven both GS, with and without extensively. It is not worth it and will be an expensive maintenance item. I tweaked my GS suspension, the way I wanted it to handle and feel through some parts changes. OE is fine for DD and touring. For occasional tracking or more planted street driving, you tweak it.
I advised him to go with the GS without the F55 suspension. (see post #2)
All I said was that a base C6 with F55 is similar to a GS with F55. AND that a base C6 without the F55 would be softer than a GS without F55 (since a GS has the Z51 suspension if it doesn't have the F55).
I did say that a GS with F55 would ride slightly better the a GS without it and that is a true statement.
Received 1,596 Likes
While I agree totally with most of the responses about the mag ride being expensive to repair and complex in operation, the base GS suspension does ride on the rough side. You might be better off with a base car w/ the base suspension. Too bad most people buy the GS for looks alone, then complain about everything else.
Received 2,061 Likes
Maybe I'm missing something, but if you like the C6 styling and want a vert, is it the look of the GS that is important vs the base?
If you want low cost, why buy a 2012/2013 simply because the seatback cushion and sound system have minor upgrades. You could buy an '05 for a lot less and use the difference to swap seats and install some killer sound or even a wide body and still have money left over.
Now about F55. It's not about soft vs firm, it's about how fast the shocks react to the road conditions. In tour mode the reaction time is about twice as long as in sport.
However, be aware that the GS has the stiffer springs of the Z51 and the Z06 sways and shocks, none of which are conducive to a comfortable touring ride as the base with or without F55.
Also. you need to consider the state of your roads. If they're rough and patched like ours in Minnesota, you're not going to get smooth, cushy ride from ANY Corvette. And if your highways are mostly concrete surfaced, tire howl will be present especially from the OE Goodyear run flats.
My best suggestion is to drive any car you're interested in on as many surfaces as possible.
The Grand Sports have stiffer suspension than the base vettes, so the base will ride "rougher" (firmer) than a magnetic suspension optioned Grand Sport. Sooo, the F55 Grand Sport in tour will ride smoother than the "non-F55" suspensioned Grand Sport.
I have a mag - suspension (F55) GS, and it's hard to put a number on the comfort level, but mine is a daily driver, and I like it for that. I had a 2008 C6 with the Z51 suspension (which is very close to the 'base' Grand Sport suspension), and I could immediately notice that the SPORT setting was about identical ride comfort, and the TOUR was slightly smoother.
But it is pretty close to the same comfort level, and if you are only going to be driving it on the weekends, you won't be able to tell the difference I bet.
On the track or twisty roads is where I can tell the difference in sway of the car, and the SPORT setting shines there. 95% of the time, I leave mine in the TOUR setting though.
When I do forget to change it back to TOUR, I do notice on the first speed bump or rough road, and it reminds me to put it back in the TOUR setting.
Here's some interesting facts regarding the purchase choices.
Combined '12 & '13 production of GS verts -- 4004
" " " " 2LT option -- 418
" " " " F55 " -- 1719
Just for reference the '08 production year by itself (most significant change year of C6)
Verts -- 7549
2LT -- 760
F55 -- 1707
Since most '12 & '13 owners are not ready to sell in relation to the '08 owners, the buyer's market is very limited. With only 10% of verts having the 2LT option the search narrows even further. If you wanted a manual trans, the search heads toward the impossible to find area, since verts are in the 85% range for A6 trans.
Verts -- 7549
2LT -- 760
F55 -- 1707
My current 2008 vert has Z51 and you can definitely tell the difference between Z51 and a non-Z51 suspension.
However I have seen posts here that said they would not want another vette without F55.
Get what feels right to you. Good luck.
It is incredibly easy to feel the magnetic ride working on my Grand Sport. Anyone who says otherwise either has a defective system or did not use it on the appropriate roads.
It is an excellent system and I am always glad I have the choice between a softer and firmer ride. It is offered on many of the other high performing GM vehicles and even on cars like Ferrari's.
GM is offering more advanced versions now, not eliminating it because it doesn't work. It is silly to think there is no advantage over non-magnetic ride cars, on the track or the street. That's why its offered on the Z06 and ZR1
If you can afford it you should get it. If you can't get it you will still be fine . . . but the magnetic ride is the state of the art and a selectable suspension adds another level of enjoyment to driving my car.
I've had six vettes. Some with Z51 and some without. I'd love to experience F55 and see what it is like. I simply couldn't feel any difference in the car I test drove.
The ride you have will be stiff for sure, if your car comes with run flats too.
