* * * * GM Recall does include C6s (MERGED) * * * *
#181
Try a Porsche..... Lots of choices out there. I like my GM.
#182
Each car manufacturer has their own sets of problems. Cars are so complicated. Can you imagine trying to think ahead 5 years about every joint, connector, and every part in general? Mind boggling. In my C3 Vette, I engineered all the weak things out. In my 13, I'll do the same. Wouldn't every brand of car have it's own problems? I read that Toyota has more recalls than any other manufacture.
#183
GM had to lie to people and cover up a problem until SEVERAL PEOPLE DIED to finally issue a recall for that whole ignition thing. Now with this headlight thing they are completely ignoring anyone with an '08 and newer model, even though it has the SAME issue and were made with the SAME defective part. Of course they are mostly out of warranty by this point so everyone has to pay the $600-800 out of pocket to fix it... with some "hope" that some day they'll repay all of us. That's bull$hit.
I guess Corvette drivers need to start crashing at night when their headlights suddenly go out before GM will finally make right with this issue as well.
#184
I must have missed the recall from GM regarding the lousy material used for the C6 headlight lenses that deteriorate over time due to heat buildup inside the lens generated by the HID bulbs as well as UV rays outside thereby reducing night time visibility. As anyone who's had the lenses replaced, or the entire headlight assemblies replaced for that matter knows, it's one expensive proposition ($750 - lens replacement/set; $1,600 - headlight assemblies/set).
#185
I received mine today. Picked up at the museum 4/6/2005. Of course no parts available. I'm going to hold off anyway because as we all know we will be getting a recall for the check air bag light any day. I'll have them both done on the same visit.
#186
Good point. On of my co-workers is an Electrical Engineer and when I showed him the photo of the wire routing in the photo, he couldn't believe the fuse block was assembled that way with such a sharp bend in the wire for the low beams headlights, especially when the unit is subjected to such high heat in the engine bay. Way to go GM.
#188
The recall isn't posted yet on the GM site dealers use to pull them up so they can do recalls and check a car's warranty. If it doesn't come up there is nothing they can do. I work at a Chevy dealer and check my VIN and the VIN for my boss's Z06 on a regular basis. I haven't gotten a letter yet either, but I am starting to get phone calls about C6 recalls.....
#189
Good news and bad news. The recall has finally posted to the GM Dealerworld site (which means the dealer can finally file the claim to get the headlight problem fixed. That was the good news. The bad news is, as posted on the site, "remedy not yet available" which basically means it's a pending recall and there is nothing the dealer can do yet to fix the problem. At least there is a light at the end of the tunnel, even tho it's probably not a C6. LOL
#190
I think most modern cars have these type lenses, and they all suffer from the same problem. Some cheap fixes have been posted on this site, but they take some elbow grease.
#191
The good news is I got a call saying the 2008's would soon be covered by the recall.
The bad news is the part is ALL back ordered and won't be in stock any time soon.
#192
I my self have the same issue and have a 2008 C6 garage kept and was told my vin was not under recall. But my car does every thing stated on the recall. What can we do to have this fixed its pretty ridiculous.
#193
http://www.nhtsa.gov/Vehicle+Safety/Recalls+&+Defects
#194
2005 Z51 Coupe - AC issue
3 Months ago i got into my vette and turned on the AC it was blowing out hot air, so i figured maybe i need some Freon, soi was thinking about taking it to the dealer to figure it out.
but when i got back into the car the next day the AC started blowing cold air, i said to myself maybe i had the thermostate on 75 0r 80 no problem. about 3 week later the AC was on and it just started blowing hot air again and i made sure i look at the temperature in side the car which was 65 degrees, i was mad so on my way home from work i had to ride with the windows down.
i thought about taking it to the shop to see what's wrong.
Did not drive the car for 1 week. i decided to take it to the shop, but when i got in the car and turned on the air it was cold. i can't figure it out.
So last week the AC was blowing hot again, came home washed and waxed the car put it in the garage and said to myself it be cool the next day i will just drive with the windows down or with the top off. Well on my way to work i turned on the AC and it was blowing cold.
I can't figure it out. I'm afraid if i take it to the dealer they will definetly rip me off.
Has any had this happen to their AC?
#195
The second safety recall covers 111,889 Chevrolet Corvettes from the 2005-2007 model years for potential loss of low-beam headlamp operation Models from 2008-2013 will be covered under a Customer Satisfaction Program. All repairs will be at no cost to customers.
Only 2009-2013 will be fixed at no cost not 2005-2007?
#196
Received 8,928 Likes
Check the attached operating conditions to see if your operation falls into these categories.
Bill
#197
C-6 recall
Hey OC, I'm a little late for this but can you direct me to the GM recall for C-6 light issues. There was a link on the forum but I couldn't ,make work. My warranty runs out in October.
#198
So are we expected to not drive our cars? Or just take a chance on a serious consequence.
I do not like the thought of the dealer working on the car... We are still dealing with a dealership issue with our top replacement (recall some years back when our top delaminated on our way back from Parker)!
#199
Exactly. It's not about the defects. It's about the way the company is trying to screw over the people affected by them. At least Honda (a company I hate BTW) will issue a recall when it realizes it screwed up.
Would this recall be covered under that?
#200
We received our recall notice in July. I ignored it since we were told we would be notified when dealers have the parts to fix the issue. Then the lights did not work one night last week. I called our local dealership (on 8/23) and they had no idea of what was going on. Then no lights again tonight.
