2013 GS in Competition Mode question...
mn6 car... without magnetic ride control.
I read the manual and it is lacking information.
I assume if the front wheels are straight, with the clutch pedal all the way in and I swiftly go to WOT... it should hold about 4000 rpm, until I release the clutch for a launch... but here's the question: Does it also have No Lift Shift, as long as I stay in WOT? I could not find this in the owner's manual.
Meaning, I did all the things to allow you to hold the gas petal to the floor, let the revs settle in around 4k, dumped the clutch, never lifted the gas, popped the clutch, grabbed the next gear, and kept going, thru the 1/4 mile run. I shifted at around 6k, and the revs never went above 6,500.
It sounded mean, barked the tires good between shifts (it was on Orlando Speedway drag strip), and I only did it once, because I did not want to find out what happened if I missed a shift.
Received 2,047 Likes
St. Jude Donor '13
I have "no lift" shifted with the launch control on.
Should...
