Service traction and active handling system
Old 05-19-2014, 01:13 AM
LS3chris
LS3chris's Avatar
Default Service traction and active handling system
I hit it from a low roll then after my car said service traction system and service active handling system... Ever hear of that happening ? Car feels like it's driving normal
Old 05-19-2014, 06:48 AM
Seadawg
Seadawg's Avatar
There is a sticky in the C6 tech forum all about this, here is the direct link:
http://forums.corvetteforum.com/c6-t...er-action.html
Old 05-19-2014, 08:27 AM
George's_Vette
Support Corvetteforum!
George's_Vette's Avatar
Couple summers ago I had these two warnings pop up on my 2009 Coupe while in southern TX on a trip. Car drove normal just kept throwing codes every time it was started all the way home to WA state. Got it into the dealer and the problem was diagnosed in my case as a failed right front wheel sensor. Nearest one was located in Reno, NV and sent to my dealer. Next week I returned, the sensor was replaced and the codes cleared. No issues since then. 33,000 miles now.
Old 05-19-2014, 09:44 AM
Richard Ames
Richard Ames's Avatar
Happened to me several weeks after purchase and the fix included a couple wheel sensors and a body control module. I was still under warranty. The HVAC head was also replaced.
Old 05-19-2014, 10:17 AM
JOEMC08C6
JOEMC08C6's Avatar
I had the alert come on right after pulling out of a shopping mall. The engine power dropped and I was thinking what the hek! I reset the DIC and the car returned to normal. Happened a couple more times and cleared in the next week. It always drove normal even though it happened those times. I took it in to the dealer, and they replaced the BCM. It's worked fine ever since. Fortunately, I had the GMPP to take care of it.
Old 05-19-2014, 10:56 AM
ls1121
ls1121's Avatar
St. Jude Donor '14-'15
Me too BCM.
Old 05-20-2014, 07:48 AM
obone
obone's Avatar
I will be picking my 2008 up today from the dealer where it has been for the past week working on this. I have had a warranty issue on this for over two years. I had their large data recorder in the cup holder for the past year and could not ever record anything. If I forgot to turn the recorder on it would throw warnings within a mile. I spoke to numerous electronics/computer engineers and they all thought that it was the yaw sensors. CHEVY finally agreed after they were able to get it to do the same in their presence. I hope that they really have it fixed this time. It has been in the shop 3-4 times and almost killed me when at 75 mph on the interstate it kicked into limp home mode after which the dealer simple reset the codes and "tightened" every wire on that circuit but could not duplicate the event. Thinking of just getting rid of it. Are the C-7 having any problems like this ?
Old 05-20-2014, 08:39 AM
psp6158
psp6158's Avatar
BCM and ECBM are known for going out on these, I just replaced ecbm after having these codes...
Old 05-20-2014, 08:52 AM
05_Z51
05_Z51's Avatar
im having the same problem. No codes though
Old 05-20-2014, 09:34 AM
trying2seek
trying2seek's Avatar
Had the same problem took it in and found that a rear hub had gone bad. Replaced it under extended warranty ($700) and works well..
To Service traction and active handling system
Quick Reply: Service traction and active handling system
