05 heater hose issue
Old 05-24-2014, 12:32 PM
turbo2001
turbo2001's Avatar
Default silicone hose kit
can anyone tell me the routing on the heater hoses 05 ls2, replacing with the silicone kit, and the old hose to the larger firewall connection will not fit with the silicone hose looking at the old hose 1 side of the hose is larger then the other. the silicone one has same size on both end's. don't know if if was hooked up wrong to begin with or not. as it will fit if I switch them around but don't want to cause ant problems with the cooling system can't find a diagram no where help please!!!!
Old 05-24-2014, 07:11 PM
turbo2001
turbo2001's Avatar
found a pic, the silicone heater hose I have did not come with the swedged end, so just bought a barbed fitting and use a small piece of hose at the firewall
Old 05-24-2014, 10:45 PM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
I have a 2006 LS2, and when I bought a silicone hose set, I had the same issue.
I e-mailed a pic of the wrong hose, and they sent me a new one that fit properly at the heater core end. The lower heater core end ID is 3/4", not 5/8".
All other (3) fittings at the block and heater core were 5/8"
To 05 heater hose issue
Quick Reply: 05 heater hose issue
