Throttle Body Torque
06-07-2014, 12:52 PM
Could some one give me the torque on the throttle body (LS3) Thanks.
06-07-2014, 03:10 PM
I tighten bolts until their tight.
06-07-2014, 03:18 PM
SUBVETTE
10 N-m or 89 lb-in for my LS2. Should be the same for your LS3, I would guess.
06-07-2014, 03:56 PM
10 ft-lbs.......or just snug.
No need to torque.
06-07-2014, 08:55 PM
Quote:
Originally Posted by
dev1360
No need to torque.
Ten foot pounds is not very much torque, if you snug them up that will be close to ten pounds. I have followed this regiment for several years with no issues.
06-08-2014, 02:58 AM
Cherokee Nation
89 lb-in per the service manual.
06-08-2014, 01:08 PM
Thanks..Sounds good..I never use a torque wrench anyway..
06-08-2014, 03:49 PM
Cherokee Nation
Cherokee Nation
Then why did you ask...?
06-08-2014, 05:20 PM
SUBVETTE
Stage Runner
06-09-2014, 05:45 PM
Stage Runner
I've
nevered used one,But i brought one,so i might as well use it...
Reason: add
06-09-2014, 07:21 PM
SUBVETTE
89 lb-in isn't very much torque; if you aren't using a torque wrench calibrated in lb-in, better to just snug by hand.
06-10-2014, 09:33 AM
SUB VETTE
Thanks...I'll use the old" 3 finger method...
