Engine light on
Make sure you gas cap is on tight. That's probably the most frequent cause of an engine light.
Just remove it, then tighten two or three clicks and see if the light goes out. Cheap fix too if that's it ... it's free.
The C6 codes can only be read by a code reader. Autozone is one of the many places that will read codes free. Or you can buy a reader for $25 or more. I spent more. I recommend everyone have one of the $25 ones and an internet link to find out what the codes mean rather than an expensive ones that will tell you directly what they mean.
