Stock Rim - Tire Size Combo
Old 07-22-2014, 06:03 PM
Nosferatu
Nosferatu's Avatar
St. Jude Donor '14
Default Stock Rim - Tire Size Combo
As title says, does this work?
265 35 18 front and 305 30 19 rears
EDIT: This is going on a narrow body c6
Old 07-22-2014, 07:16 PM
Jose M
Jose M's Avatar
Hope it does work. Just bought new wheels 18x9 front and 19x11 rear and that is the tire combination I am going to use.
I have a C6 base too
Old 07-22-2014, 11:22 PM
raspyc6
raspyc6's Avatar
bump..have seen 255 40/18 and 265 35/18 as front option . use these numbers with 305 30/19 out back and active handling parameter excesses should not be an issue as you stay below the critical 4.7ish mark
Old 07-22-2014, 11:25 PM
raspyc6
raspyc6's Avatar
dude...you could do a 295/35/19 outback like I was doing and retain front stock fitment. just a thought man
Old 07-23-2014, 08:02 AM
Nosferatu
Nosferatu's Avatar
St. Jude Donor '14
the AM bump. I want to know if this is work so I can order the tires today/tomorrow.
EDIT: I'm told there's no TPMS on these so do I need to install them or will I throw a code?
Old 07-23-2014, 09:25 AM
haljensen
Support Corvetteforum!
haljensen's Avatar
Those tire sizes are NOT listed for stock wheel widths.
If you are getting wider wheels also then the fit depends on the design and offset of the wheels.
Yes, you need TPM's. Use your old ones in the same position and you won't have to buy anything.
Old 07-23-2014, 10:39 AM
familyman's C7
familyman's C7's Avatar
St. Jude Donor '14
You will get a warning message on the DIC to service the tire monitoring system and the warning light will appear on the tach side of the dash.
Old 07-23-2014, 10:47 AM
jackcasual
jackcasual's Avatar
These are the sizes I bought. Stock rims. Michlens. I did it for the look. I wish I hadn't. It changed handling of car when driving spiritedly. I feel tires squirm on rims. The cars sets differently in a corner. I don't like it. I believe the tires are just too wide for stock rims.
Old 07-23-2014, 11:41 AM
Knoxrower
Knoxrower's Avatar
I've seen upsize recommendations of 255/40/18 and 295/35/19
The only time the 265/305 size is recommended is when you are mounting them on the ZR1-R1 wheels or comparable.
Old 07-23-2014, 01:33 PM
Jose M
Jose M's Avatar
raspyc6
will the 295/35/19 fit even with the rear fender?
Old 07-23-2014, 02:06 PM
stein3282
stein3282's Avatar
That's what I'm running on my 06 base. Hankoook Ventus K110
Old 07-23-2014, 04:44 PM
raspyc6
raspyc6's Avatar
Originally Posted by Jose M
raspyc6
Yes, sir. ZERO fitment issues on our stock c6 rims. It looks better too IMHO.
Old 07-23-2014, 05:26 PM
Nosferatu
Nosferatu's Avatar
St. Jude Donor '14
hmm...I enjoy the suspension work I did so that tells me that maybe the 305s are too wide and the wheel walls warp under heavy turning.
Is 295s worth it then on the factory 245 size tires or no? Would that throw things off? I'm starting to wonder if 305 and 265 combo is a good idea or not...
Old 07-23-2014, 06:35 PM
haljensen
haljensen's Avatar
They're a good idea on correct width and offset wheels.
They are a poor idea on stock width and offset wheels.
Old 07-23-2014, 06:48 PM
raspyc6
raspyc6's Avatar
295 35/19 rear w/ stock 245 40/18 works flawlessly...I had that setup for 2-3 years with never even once having traction control issues or the like...ever. The only reason I went back to stock size out back was to give the Conti Extreme Contact DW a shot.
Old 10-18-2015, 09:05 AM
skar
skar's Avatar
I know old post . So would I loose any performance 1/4 mile and handing
Going up one side . 265 front 295 rear combo is what I was thinking .
Or should I stick with stock. Need new tires befor Spring . ( base 2008 auto)
To Stock Rim - Tire Size Combo
Quick Reply: Stock Rim - Tire Size Combo
