Does 2011 non bose have VSS at amp?
I see that Bose cars have the VSS wire at the amp. Does my 2010 non bose have it there also? I have volume control on the radio. XM and Blue tooth. And controls at the steering wheel. Is the VSS only behind instrument panel on my car?
On non bose case since they will not have the VSS plug at the back of the radio, you have to tap the VSS wire up line instead (behind the dash the best location to tap).
http://forums.corvetteforum.com/audi...se-w-pics.html
Bose VSS wire plug is at the back of the radio, and in the case of a Bose car without a Nav radio, the Vss connector plug is just taped back on the large radio harness since it not used with the non-nav radio.
