Swap out factory radio
Jim when you are in I Tunes you do know you can tailor the sound of each song. If you don't know right click a song and go to get info. In that screen go to options and set the EQ for that song ( your preference )and raise the volume bar to between 3/4 and full and click ok. Your volume will now be louder when you play back from your I pod.
Received 2,047 Likes
St. Jude Donor '13
Thanks, I'll try that.
Will it work that way if I buy a song from ITunes, or only when downloading from my CD?
Yes once the song is in your I tunes library ( however it got there doesn't matter )or if you are seeing the library from your Ipod you can do it. You obviously have to have your I pod plugged in to make the changes. With your I pod plugged in when you hit the ok button after you make the changes you will see the progress bar on the top of the page saying " updating files " and you now have changed the setting for the song you have just altered.
St. Jude Donor '13
Thanks!
No problem. If you have any problem doing it pm me and I will give you my telephone number and will walk you through it when you are on your I tunes account and me on mine. Makes a world of difference when you change the settings for each song. Although some songs take to the change better than others but 90% of them benefit from the change.
I bought my Kenwood DNX9990HD from Dennis. He kept providing support for years after the sale and I suspect he would be there for me today.
Our only disagreements have been over the interface between the Kenwood and my Corvette. I had continuous trouble with his. May have been because I was the installer, but even Kenwood couldn't make his work. I gave up and had Joe D's in Bristol Connecticut make it work. They changed the interface and the problems disappeared. I can even have OnStar if I want it.
The reason I bought the Kenwood is that it has Garmin. VERY intuitive. Other than money I don't understand why all the manufactures don't use it.
I have a hud in my 6 speed 2005 vert and have never seen the turn arrows displayed on it. What do I have to do to see that?
