NPP Module - Good or bad?
Is there anyway I can see if my npp module is still good?
I believe its broken but I would like to confirm before I buy one if it's possible
It is the stock unit. I believe the module is shot behind the passenger tail lights.
when I purchased the car, one butterfly was wide open an the other Butterfly was half way open, 10amp fuse is good. But the butterfly's won't work. all lines seem fine
For now I did take a screw driver an opened them manually
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
sorry for the confusion, both sides do not function at all, one just happen to be stuck wide open wail the other butterfly was just stuck half way open. as of rite now I opened both butterfly's so they get equal pressure
Received 1,497 Likes
No-IL Events Coordinator
C6 of Year Winner (appearance mods) 2019
2018 C6 of Year Finalist
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
The "25794609-Solenoid" went bad on my 07 Z06 leaving the flaps to default open. Drone was awful! Part was replaced under "good will' from the dealer.
hmm I thought it was number 21 in the diagram. I think I might just leave it, it could be a vaccum line to the front of the car, I do know the passenger side skirt was repainted, so maybe they pinched a line doing that
CI 1-4-5-8-9-10 Vet
One option would be to find the soleniod up front that switches the vacuum on and off. Apply vacuum there (you can buy vac hand pump at auto parts for $15 +/-). If it closes your valves, you'll know the lines from front to back are good and can focus under the hood.
If that doesn't work, you may get lucky by searching, maybe even on google if you don't find it here. Sorry, I'm not more help. I havent had to work on mine (yet) so I don't know more than that.
