Electric seat not working 13 gs
My key remote fell out of my pocket while driving and while searching under and behind the seat I had moved the seat all the way up and back a couple times...finally found it wedged between the seat and console. The problem now is my seat won't operate and it's all the way forward and is dead! I checked the fuse and the wire connectors that I could see and nothing. Is there a separate circuit for the drivers seat? The passenger still works. Is there a connector under there that I should be looking for? I guess I could always unbolt the seat......
Several forum members have had problems with the connectors under the seat. I'd check them first. Wasn't sure whether that was the connections you said you checked or not.
I fixed it! Decided to pull the seat out and as soon as I got it pulled up and leaned over it started working again. So I checked the connections and all seemed good so vacuumed the carpet then bolted it back down. I guess it will work till next time........
