thermostat suggested
Old 09-02-2014, 09:54 AM
Gmf07
Cruising
Gmf07's Avatar
Default thermostat suggested
Getting ready to put in clean radiator fluid. Do you think a new thermostat in s in order? 160 degree? 2007 m6 with 15000 miles.
Old 09-02-2014, 09:55 AM
Don-Vette
Don-Vette's Avatar
No.
Old 09-02-2014, 10:02 AM
Gmf07
Cruising
Gmf07's Avatar
Originally Posted by Don-Vette
No.
Old 09-02-2014, 10:33 AM
Cyber Grey
Cyber Grey's Avatar
Originally Posted by Gmf07
Yes to new thermostat but not 160.
Old 09-02-2014, 12:30 PM
Don-Vette
Don-Vette's Avatar
My motto is:"if it ain't broke, don't fix it." Besides you don't need a 160 unless your running a tune with mods IMO.
Old 09-02-2014, 12:34 PM
Bowtie_Brigade
Bowtie_Brigade's Avatar
160 = luke warm heat!
EVRose
EVRose's Avatar
Old 09-02-2014, 01:24 PM
Cyber Grey
Cyber Grey's Avatar
Stock engines need hotter heat to make them run better. That is the way they are programmed.
Modified engines can use a 160.
Old 09-02-2014, 01:29 PM
P0234
P0234's Avatar
Remove it and the caddilac (sic) converter...they were put in by the EPA who wants you to ride a bike or drive a Prius instead. Don't listen to anyone else here that says to keep it in, they work for the EPA and Obama.
Old 09-02-2014, 03:06 PM
Guinzu
Guinzu's Avatar
^ That's some dumb **** info...
Old 09-02-2014, 08:42 PM
vettman96
vettman96's Avatar
Wow.......
Old 09-03-2014, 02:54 PM
Jimbeaux
Jimbeaux's Avatar
I agree. If the decision is made to replace the thermostat with new however, might as well replace the water pump too. That's the only time I have replaced mine. My current (stock) stat has been for over 100k miles.
Old 09-03-2014, 03:19 PM
BSE1956
BSE1956's Avatar
Keep in mind that your engine was made to run at a particular temp. +/- a few degrees.
Running a cool (-35 degrees) thermostat will fool the fuel management into thinking it is always "cold". This will make for a richer mixture. Not good.
Other wear problems can occur as well. Stick with the 195.
Note: I flushed and changed my fluid about a month ago (13,500 miles), and the car generally runs 2-4 degrees cooler than before.
Very slow process. Easy, but tedious. Make sure you have other chores to do while waiting for the heating & cooling cycles.
Old 09-03-2014, 03:53 PM
billyboy47
billyboy47's Avatar
St. Jude Donor '17
i have to admit that i removed the CAT on my new 1981 vette back in 82 and it ran just fine. actually, it sounded twice as good as my buddies 79 and 81 corvettes. (we all bought them at the same time) i swear it sounded like i had the npp exhaust on that car. just sayen
Old 09-04-2014, 09:24 AM
6Speeder
6Speeder's Avatar
Actually, that's NOT true. The ECM will run the engine in closed loop mode (run 14.7 A/F) when the ECT gets above 120ish, depending on other conditions. It WON'T run rich with a 160, compared to a stock thermostat. It will, however allow more timing, hence more power, because the engine will not be as prone to knock. Now, a 160 won't get your engine to run any cooler in protracted stop and go traffic unless you reprogram your fan to come on at lower temps, but will allow you to run at/about 170-180 when at higher/freeeway speeds.
To the OP: You don't NEED to change the thermostat, but it won't hurt, and in some conditions, will help.
Old 09-04-2014, 11:59 AM
Gmf07
Cruising
Gmf07's Avatar
Thank you
Old 09-04-2014, 04:38 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
May work for short bursts of wide open throttle but other than that doesn't do any good. As soon as you start running hard for more than a few seconds the coolant temp goes to the max level based on the cooling capacity of the cooling system. Typical C6 coolant temps when running hard (speeds above 100 mph and WOT) for 5 minutes and above are around 220 no matter whether you have the stock 186 deg thermo or a 160. Only way to bring it down is to add cooling capacity. Reprogramming the fans doesn't work since they inhibit air flow through the radiator at speeds above 35 mph and have to be turned off.
Bill
To thermostat suggested
Old 09-04-2014, 10:45 PM
Vet Interested
Vet Interested's Avatar
Received 2,092 Likes on 1,207 Posts
Sell what you're smoking. You are gonna be rich!
Old 09-05-2014, 12:46 AM
Rebel 1
Rebel 1's Avatar
Great explanation and absolutely correct.
After changing to a SLP 160* stat my cruising temp. is 174-180*, oil temp. is 210-218* with no other changes.
There is no difference in gas mileage.
Changed it out 3 years ago and completely satisfied with it.
Bob
Old 09-05-2014, 12:58 AM
ProfessorDeath
ProfessorDeath's Avatar
St. Jude Donor '13-'14
Worst suggestion I've ever heard. No reason for a new T-Stat. If you are planning mods in the future a 160 wouldn't be a bad investment, but if you're just flushing? No need for a swap of any kind.
Quick Reply: thermostat suggested
