lowering on stock bolts ….quick question
For those that lowered their C6's on the stock bolts, how much lower did it give you ?
any correlation to how many turns = how many inches ?
I can't tell you how many turns, but I can tell you that you won't get "inches".
I turned it all the way on my 2005 and maybe got like a half inch drop. If you want to go lower on the stock bolts you will need to cut some of the bushing off.
Homer, understood the 'inches' thing, I should have said 'fraction thereof'
Received 2,884 Likes
2021 C6 of the Year Finalist - Modified
The above car sure doesn't look lowered!
I got about 3/4 of an in.
I am with tanks full 2 tight fingers between top of tire and top center of fender. I am not thick fingered either.
I assuming that with the stock bolt run all the way and no cut bushing ?
Thanks for posting GS Driver......were those taken after you drove it awhile or just after you lowered it...? The car will settle after some driving.... Nice car by the way....how do you get along with the power adder.......?
Luster, did you get a new alignment ?
