Defrost
Defrost
2005 C6 - The A/C blows cold and through the vents as it should. I push
the defrost button and the air moves to the floor board and not
to the defrost vent on top of the dash. I push the defrost button again and it circulates back to the A/C vent. In the mornings while running the A/C, it will cause moisture on the outside of the windshield in front of the defrost vent. Does anyone know what would cause the defrost not to work?
I would appreciate any help on this.
Old thread. Mine just started doing this too. The air would also go warm/hot at times while the AC was on.
There was a thread about the 'mode doors' that re-direct the airflow, that may address your problem. I'll post a link if I can find it.
Major PITA to repair. Good Luck
John
Thanks, KJ. I don't believe mine is due to a delaminated mode door because it doesn't make a weird sound. It acts like the vacuum hoses that control it are switched. However, does the C6 use vacuum hoses to actuate the mode door? I don't even know where to begin looking. I had the var in for a recall and hope the mechanic didn't mess things up.
John
John
just as a side note, i believe there are actuators that move parts (like shades) inside the unit, thats where usually the problem is when air moves incorrectly or fails to move properly.
this is a blow-up of the a/c unit. i think (but not positive) that the shades are item #1. the actuator is item #8, there are 2 of them(i know it show 3 of them but parts list says 2 required). also #29 is an actuator.
i am not a a/c unit repair person, but from what i can tell...
the purple area is for the dash vent air ,
the brown circle area is the shades
this is info i had saved from many years ago, i dont know what year the blow-up is for, but suspect its valid for all C6
the parts blowup shows actuators..
SOLVED! Disconnected the battery. Defrost works fine.
Either in this thread or another, someone mentioned that disconnecting the battery has corrected this issue with some who have experienced. I did just that. Disconnected the negative cable from the battery for one minute then reconnected. Defrost now works perfect.
God bless!
God bless!
