headlight lens
no polishes, it seems once you polish and remove the outer layer of UV protective coating your screwed they get much worse very rapidly and polishing is endless after that.
i never did anything with mien expect wash with the rest of the car.
Received 2,045 Likes
St. Jude Donor '13
Plexus is supposed to be pretty mild, but I just use GM Glass Cleaner (spray can) which is approved for plastics. Also use it on the transparent top and dash gauges/nav (blow off the dust first)
soap and water and meguiars ultimate wax as there are no abrasives in it..
