Is this tune conservative enough for track days?
I couldn't get no bites in the "scan and tune" forum, so let's try here
https://www.corvetteforum.com/forums...-specific.html
I just want to be sure I don't run too lean, if I hammer it for a half hour with this tune. I won't have my wideband sensor installed before the event, so just looking for experienced tuners to make me feel a little more at ease....
Thanks in advance for any feedback.
I'll be honest it's kind of hard to tell with that graph considering it doesn't show a "Max A/F" at a fidelity that is really useful. It leans out at 3k then gets more rich after about 3300 and then stays in what I would think is in a pretty safe/rich AFR at the top end; I'm no expert though.
What kind of wideband did the tuner use. Do you have cats? It's really hard to tell without a real data
Fuel cools the motors (why you want to run the motor at 12.5 or greater where it should pull most of the power), so regarding dropping the AFR down below 12.5, your just asking to over heat the motor over longer periods.
Next was this tune only done on the Dyno alone, or was the car taken out to road test final the tune instead?
Also, might help to just post the tune file if you are asking about a tune.
Lower should safer to a point.
I'll ask them to email me the tune in the meantime, for both my factory tune and this installed tune. I feel better having it saved in two places anyway, in case something happens to the shop, etc.
The tune was done on the dyno alone. It feels good on the street, but I'll wind it up in a safe stretch of highway, and pull the plugs to look at them too. In fact, even at the track I may pull the plugs, just to give me more of a comfort factor.
