help Porting in Baltimore Area
Its a little hard on system porting if you are matching the runners, since the heads have to be ported/temp mounted first without being valve train assembled so you can dry fit the intake to the mounted heads, then head to intake runners matched to each other.
If my post is going to be edited by a moderator then I will delete it in its entirety. Sharing information should be the cornerstone of a car forum not censorship
Last edited by C6FirstVette; 09-29-2014 at 02:19 PM. Reason: Removed link to non-supporting vendor
Supporting Vendor
Received 1,012 Likes
If you feel like shipping them we can give you a great price.
We port everything via our Superflow 600 flow bench
American Heritage Performance
310-326-2399
http://www.americanheritageperformance.com/
Or if your looking for something more local to you hit up RaceProvenMotorsports. They are a quality shop and a forum sponsor.
310-326-2399
tune time performance has a $225k CNC machine.. and a load bearing Dyno. Call Matt...
check them out.
https://www.facebook.com/TuneTimePerformance
they also have a big show coming up in a couple weeks. usually a very good time. they are very approachable that's a big reason they are as successful as they are.
https://www.facebook.com/events/448512581923139/
check them out.
