Gas cap problem-Traction control
Has any one had a problem with the gas cap not staying tight??? It causes the DIC to flash the "service engine" light and the DIC says the "Traction control" needs service and the car goes into low power mode. The "traction control off" light comes on. I went to the dealer the first time it happened and don't know what they did, but got it back and they said the codes were cleared. I find out it happens after getting gas, if the gas cap is not in the right position. It seems the cap is very loose when I put it on and does not get tight and if it's in the wrong spot, all the warnings come up until I go out and reposition the cap, and then everything clears on the DIC. Any ideas???
Were you intending to post this in the C6 section of the forum?
In your details above, it's time for a new gas cap. It should always be tight and should be tight with a quarter turn and then a few clicks.
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
Now that you are in the right forum............
I have found through trial & error, that the gas cap needs minimal pressure put on it to correctly lock. I was pressing inward on the cap and it would not lock in place. Just place the cap in the neck and gently turn clockwise 1/4 turn.
OK, maybe the gas cap has absolutely nothing to do with traction control, but loosen up your gas cap and see what happens. When it's not tight, my DIC lights up with traction control failure and reduced power mode.
I tried putting the cap in lightly and turning a 1/4 of a turn, and guess what, it locks. I have been pushing harder and harder trying to get it to lock and that doesn't work. I have not driven the car yet, but I'm sure it will drive fine. Thanks for the response.
I've had the 427 for over a year, so I guess I got it right by accident some times.
