GS suspension
My '10 GS glovebox list code FE3 and also calls out Z51. I didn't know FE3 was associated with Z51.
Correct me if I am wrong...
The GS should have Z51 front sway bars and Z06 rears. The shocks should be Z51 all around, unless you have the F55 (MSRC) option.
2023 C7 of the Year Winner - Unmodified
The build sheet on my 2012 shows FE3 H/D and Z51 Sport Pkg.
All GS's have the FE3 H/D shocks unless your car has the "F55" option. The FE3 fronts are the same front shocks found on the "Z" cars , but the rears are different.
GS is sort of a hybrid of FE3 - Z51 parts and FE4 - Z06 parts, plus unique rear shocks.
......Z51 springs
......Z51 front sway bar
......Z06 rear sway bar
......Z06 front shocks
......UNIQUE rear shocks
......Z51 springs
FE3 springs are one specific component "thing" in that package, as are the J55 HD brakes (that we all refer to as Z51 brakes).
GM did away with the Z51 nomenclature in the late 2,000's (I think 2009) and calls it the Z16 package on the newer cars. If you have Z51 on your 2012 build sheet please post it.
Also the alignment specs for the FE3 is the same as the FE1 and FE2, and NOT the same as the FE4(Z06) or FE5(ZR1)
