Stuck driver window
Stuck driver window
Window is stuck in the position of when the door is open. Won't go all the way back up. Tried resetting like when they get stuck all the way up. How do I get it to reset? Anyone have this problem?
Are you saying that you used the procedure to reset the window indexing?
If not, here it is.
If not, here it is.
With the engine running and the window down, close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done. Don't forget the other window.
I just did the window indexing procedure, but the driver door window would not re-index. I disconnected the battery for a few seconds and tried it again and it worked.
Scott
Scott
