tire pressure
It depends on if you believe the sales pitches of those selling nitrogen in tires. If you do believe them you will need to evacuate all air/nitrogen in you tires and replace with pure nitrogen as soon as possible. If you don't believe them just top up with air. It is 78% nitrogen anyway. There are legitimate reasons for using nitrogen but for most drivers there is no need in spending the money. Just keep your tires at the proper pressure.
People misunderstand the advantages of nitrogen use in tires. Yes dry air contains 78% nitrogen. However what folks are overlooking is the water vapor content of normal air. This water vapor expands at a high rate and causes pressure swings. Nitrogen by comparison is much drier so it's pressure remains more constant over a wider temp range. While I don't think I'd pay to have it put in my tires, it does offer some tangible benefits.
FWIW department. For history, I've competed in SCCA since 1984, autocross, time trials and road racing, 7 years of AMA racing before that. The seperation process to get the "pure" nitrogen seperates out moisture, too. Advantage racing, dry air won't expand like moist air. Tire pressures stay fairly constant from leaving pit lane, to taking the checker. We compensate by leaving pits with 4-7 psi lower than optimal, knowing as tire heat up, psi will go up too. I have never asked any of my racing buddies in Arizona, but they probably don't understand the hubbub, since their air is already dry. Down South where we can cut our air in the summer, it really makes one less variable. BTW, I've never used it, nor do I plan to racing or on the street.
